You had installed the 4.9 Kernel earlier but didnāt followed the updates in that testing thread.
Change deb http://apt.osmc.tv videoimprovevero main to deb http://apt.osmc.tv videoimprovevero49 main and update again
Many thanks!
I have changed the sources.list. How can i start the update via command line? I cant access the osmc menu.
sudo apt-get update
sudo apt-get dist-upgrade
My system is running again. Your support ist really perfect - thank you!!!
I can confirm this behavior, if you have CEC set to turn off your TV on kodi shutdown. It turns off your TV when updates are started, because kodi is then shut downā¦
But I donāt think this is a bug as such, as it does exactly what it is set to doā¦
But it would be nice if, for example MyOSMC would temporarily disable this setting when an update is started⦠if that is even possible?
CEC is however behaving difficult, already for a long time for me.
When I press a key in kodi when everything is turned off: Receiver switches on, TV switches onā¦then when the TV is almost ready, everything is switched back off⦠and then on again very quickly sometimes so quick that the TV was still āshutting downā and apparently misses the new CEC ON command ā¦(some times this repeats 2 or 3 times). When I then finally get an image on the TV, the receiver suddenly switches to TV audio-input instead of OSMC-input. I have to manually switch CEC (which I do using Yatse) to have the receiver tune back to OSMC-input⦠and that also repeats itself 2 or 3 time before it finally steadies in the state as it should be so I can actually use Kodi. Both of these phenomenons donāt occur every time. some times only the switching on/off, some times only the input-switching, some times both, some times none of theseā¦
But I have the impression that it got worse since this updateā¦I didnāt experience the ānone to theseā yet since the update.
And a subsequent problem I now have, since this update. Whenever Iām watching something else beside OSMC (for ex. satellite box). And Iām finished, turn off the TV, which triggers a CEC OFF on the receiver and satellite box. Then suddenly everything switches back on, tuned on OSMC (now always without turning off/on/off/on or receiver switching to TV audio)⦠And this keeps repeating when I again turn off the TV. this only stops when I let everything switch off by turning OSMC to Standby mode ⦠then everything is turned off by OSMC and stays offā¦
However once upon a time, when I did not yet have an OSMC Vero 4k, but a custom PC with CEC adapter, it all just worked⦠It even also just worked initially (04/2017) on my OSMC Vero 4k ⦠But after certain updates, it started to behave more and more like what I now describedā¦
Never actually bothered to report it here, as it was not as bad as now, and I could live with itā¦
My satellite box also has some CEC issues (forces receiver input back to itself whenever input is changed, and never turns on or off the receiver, only the TV),⦠so I was used to it up to a certain degreeā¦
But now it is starting to get a bit too annoyingā¦
But maybe I should start a separate topic for this?
Maybe, but I would suggest reviewing your CEC settings in Kodi and your AVR. You probably only want to have Kodi set for turning your TV on and off (not TV and AVR) and additional settings for changing sources or power should probably be set to ignore or pause playback. It sounds like you have more than one device trying to control power state and unfortunately it seems that most CEC capable devices use power toggle instead of explicit on/off commands. The trick seems to be to only issue power on/off to your TV and allow your TV to turn your AVR on/off. Also you donāt want your AVR to dictate power state of connected devices (ie when you power off your AVR it sends a power toggle which may turn devices on instead of off).
Hello
I have problem booting after upgrade to new version - after installation and reboot I saw only black screen. I think that something went wrong and completely reinstall system. On clean system I“m continue with installation of @joakim_s X11 simple desktop.
After installation of this I can“t find in Program Addons X11 launcher and after reboot I saw again black screen. It is possible to connect to RPi over SSH and I have these logs: https://paste.osmc.tv/doluzeyuwe
After some time when I move with mouse I saw this picture
When I tried
sudo reboot
actual session was closed but raspberry not restarted
After unpluging of power I saw again the black screen and these logs: https://paste.osmc.tv/uxewokosep
Strange is, when I testing this [TESTING] Debian 10 Buster
all working good, but after official update i have these problems.
Anybody have same problems?
I known that X11 simple desktop is for stretch, but I doÅt known why is broken also booting and how to uninstall simple desktop or fix this problem.
Thanks for help
Jan
HI Sam & co,
Just wondering if the new Vero 4K image is available on the Download site? Looking to do a clean install, I can see the link on the download page but it says āmd5 not foundā and clicking the link says āNot Foundā.
Thanks heaps!
I made clean install over pinn / Noobs . Now I have kodi 18.8
Jan
I will look into this, on vero4k to begin with, the son has inherited my pi3 for coding purposes.
I“m glad to this. If I can help you with any testing, logs etc. please let me known. I will be happy to repair this very good feature.
Jan
Hi Guys,
Quick question⦠I am running a Vero4k+, however when I look for any update there is nothing available?
I am on June 2020 (2020.06-1)
Should the new version be updateable from the unit ?
Or do I have to download an image or some such and stick it on a thumbdrive??
Steve
Not sure what was going on, but just checked the website this morning and can now see the Vero 4K image as listed. Thanks!
Yes, would be automatic update. You can manually check under MyOSMC - Update.
If manual check also doesnāt work I suggest to upload logs via MyOSMC so that we can check.
Thanks for the prompt reply.
I was using MyOSMC - Update and it was blank (Been trying for a couple of days now).
Went back in an hour or so after posting my enquiry and as if by magic it was there and available !
Update is now complete and everything seems fine.
Steve
after the update the power button shuts down vero
Please find the solution to this hereā¦
To bring this back to the behavior your looking for please SSH into your RPi and sudo nano /etc/systemd/logind.conf and change the line #HandlePowerKey=poweroff to instead read (make sure to remove the hash) HandlePowerKey=ignore and then ctrl-x, y, and then enter to save and exit. Now reload that with sudo systemctl restart systemd-logind Your power button should now only trigger the kodi menu. @sam_nazarko should this be a change on our end? I canāt think of why we would ever want theā¦
Update ran perfectly on two devices. Nice work
That issue should now be resolved and the images are available on the site and via the installers.
This installer now uses our 4.9 kernel so that we can also get some more testing. The OSMC system itself still uses our 3.14 kernel however.
Update ran perfectly 3/4 RPIs. One said it couldnāt install. Reformatted SD card and did clean install and backup of settings -all good now. Seems a tad faster than old version
