If someone has a Panasonic Viera TV, what options you are using for:
REMOTE BUTTON PRESS DELAY BEFORE REPEATING
REMOTE BUTON PRESS REPEAT RATE
REMOTE BUTTON PRESS RELEASE TIME
These option you can find in Settings > System > Input devices > Peripherals > CEC Adapter
Regards.
These setting work best for me on my Panasonic Tv.
REMOTE BUTTON PRESS DELAY BEFORE REPEATING = 1000
REMOTE BUTTON PRESS REPEAT RATE = 250
REMOTE BUTTON PRESS RELEASE TIME = 500
Thanks guys. I used 500 250 500 values, but from time to time, kodi buffers few remote controller key presses and than after a second or two all key presses are executed.
It is very annoying.
I will try to test your set up to see is there any change.
