Hi there,
upgrading the Hardware from Raspberry Pi 2 to 3 or 3+ was easy because it was using the same Image (see also Pi2 to Pi3 Upgrade)
Because Raspberry Pi 4 has a different image as for Raspberry 2, 3 and 3+, I’m not sure if one can upgrade the hardware that simple (It even switches from 32-bit to 64-bit). Is there any place where I can have a look into the differences between the images? Is it possible (even with some effort) to upgrade without reinstalling?
What I have done so far:
What I am currently doing:
- Waiting for the upgrade from v18.9 to v19.1 on a Raspberry 2
What I am planning to do:
- another backup
- enable multiarch for armhf+arm64
- install rbp4-mediacenter-osmc and rbp464-kernel-osmc (and resolve dependencies and apt autoremove, etc)
- extend /boot/config.txt with arm_64bit=1
- shutdown
- backup, you know
- placing sd-card in Pi4, boot and be happy
Am I missing something obvious? Do you think this will also work for updates in the future?
You should install OSMC from fresh on the Pi 4 using a Pi 4 image.
It worked
Here’s my little unclean history (the missing numbers have been debugging).
# make the system multiarch
465 dpkg --add-architecture arm64
466 apt update
# this command crashed, If you execute command 483 before this, fixing the broken dependencies may be easier
480 apt install rbp4-device-osmc
# comment the line with the exit 1 inside this file (package should be marked as essential instead of doing this)
483 nano /var/lib/dpkg/info/rbp2-device-osmc.prerm
# now the removal works
490 apt remove rbp2-device-osmc
# try the installation again
491 apt install rbp4-device-osmc
# there are some problems because the packages are not having correct Break: and Conflicts:
492 apt remove rbp2-kernel-osmc
493 dpkg --remove rbp2-kernel-osmc
494 apt install -f
495 dpkg --remove rbp2-ftr-osmc
496 apt install -f
# remove old kernels, you can check your old kernels with apt list rbp2-image\*
497 dpkg --remove rbp2-image-4.19.122-2-osmc
498 dpkg --remove rbp2-image-5.10.32-2-osmc
# now the new kernel (64-bit) is installed and old ones are removed. This means you cannot boot on rpi2 anymore, (I didn't try rpi3).
499 systemctl poweroff
I forgot to set arm_64bit=1 in config.txt but switching the sd-card to the rpi4 worked anyway, so who cares ;). The only thing I had to do was to place the new MAC in my DHCP-Settings and reenable ipv6 (Enabling IPv6 in OSMC - #9 by ActionA)
I know, there are still tasks missing, like switching some applications from armhf to arm64 like apt and coreutils and stuff. I might also get problems when updates are coming in place but for now, I’m happy
– and it was waaaaay less work then reinstalling because I’m running a lot of other applications on the device – that’s my reason for using osmc, it has debian
You’ve bodged it a bit, so well done.
cat /proc/cmdline probably still shows osmcdev=rbp2. You should fix that up by editing cmdline.txt.
If it works and you don’t anticipate installing any updates, then great.
Otherwise, you should definitely reinstall, and consider using something like Ansible to automate your OSMC deployment and make things easier when re-imaging.
