just got a rasp pi 2 toady and first thing i did was try out osmc. I’ve been using raspbmc for a long time on a daily basis and I’d like to say thanks Sam for a very good and stable product.
the pi2 boots very fast with osmc and a cheep microsd card. pretty impressed.
I use the xbox remote playback kit USB reciever + remote for remote control support. Has this been added into OSMC alpha 4 yet? i can see in dmesg that it is detected :
[ 5.126891] input: Chinese-made Xbox Controller as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input1
but when i use lsusb (which i had to install) i get an odd response. :
Bus 001 Device 006: ID ffff:ffff
and the device doesn’t work either. I know the receiver and remote work OK as they work well on an pi1 with raspbmc.
i have searched but can’t find an answer, and saw that you did get lirc and remotes included into your blog for Alpha 3.
Is this a pi2 thing, or a osmc thing?
Also, did you notice that the mpeg2 codec is already included in the pi 2? i just bought a license, but then tested afterwards without the code, and it works out of the box! will try the VC1 later.
Sam, when you say Pi1 and Pi2 are you meaning Raspbmc and OSMC? I use an xbox1 remote on Raspbmc and tried OSMC alpha 4 on my Pi1 and the remote is not working.
Ben
I just got a Pi2 and am attempting the same thing - I was previously able to use the XBox DVD remote without any problems on my original Pi model B with Raspbmc, but it won’t work for me now with OSMC. I see that the functionality has been added, but I’m not sure what I need to do to get it going - any help would be appreciated!
I just dug it out a few days ago to check the status, and yes, it appears the remote works now! I just have to wait to upgrade my power supply because I had a rainbow in the corner every few seconds, but I’m really excited that I won’t need to redo our remotes!
I have an Xbox Remote Dongle attached to a USB to Xbox cable I got on Amazon a few years ago. When I plug it into a powered USB hub with the Raspberry Pi B, the remote works fine. The Pi is powered by the USB hub.
So, I did the same setup for my new Pi2, and the remote works. However, my Pi2 wasn’t getting enough power, so when I plug the Xbox cable into the Pi2, the remote does not work. I really don’t want to have to have a powered USB hub just for the remote, so I’m wondering if it is just possible to plug in the cord, or should I just look to a new remote? Is there a confirmed working IR remote that is fairly cheap and plug and play?
I tried Jebus’s solution, but I wasn’t able to FTP a file into OSMC - how do I get that file in there? Thanks!
You’ll have to SSH into the Pi to create the file (there’s a million tutorials out there), but have you tried updating to RC3? I think I saw in a thread that Sam mentioned this issue would be resolved in that release - so I’m guessing there would be no need for the fix above.
I updated mine to RC3 after I had done the fix, and everything is still working just fine.
haha… I just noticed that ‘the thread’ I thought I had read where Sam mentioned that the fix was implemented was this thread - only a few posts above mine.
You can SSH into the Pi using a program called Putty. You’ll need the IP address of your Pi, and the username & password is ‘osmc’.
Once you’re logged into the Pi, enter this:
sudo nano /etc/modprobe.d/xpad-blacklist.conf
That will open a sort of text editor. Type in:
blacklist xpad
And then I think you hit CTRL ‘X’ to exit. It will prompt you to save the file - just hit yes.
Then type ‘exit’ to get out of your SSH session and reboot the Pi. Hopefully that will do the trick.
