I’ve did a fresh install with the latest image. Then I’ve initiated a manual update and one was found and installed. After that one the custom overclocking settings in myOSMC didn’t work anymore. This was one hour ago.
With the latest image there is no problem.
Markus
Looks like the config.txt is more generic and the overclock options in OSMC doesn’t make a difference if there is an Pi 2 or a Pi 3, or can’t differ
I’d like to know that too! what are the default cpu, ram, etc. values for the pi3? Because right now it sets the cpu clock to 900Mhz… (with all the latest updates to osmc)
I just did a fresh install on my RPi 3 and looks like the speed is set to 900mhz. Could someone please provide the correct settings to put in the overclock section to get it to run at the normal speed?
Remove all speed settings and they will be set as default and if you are on the latest updated version and going to MyOSMC Overclock choosing “normal” and it is not doing that for you please provide debug logs.
So I notice that even though under “My OSMC” the cpu seem to be set to 900 mhz at default, if you look at system info from Kodi —> hardware, the CPU speed is set at 1200 mhz (as expected). I’m going to guess that kodi 1200mhz is the correct representation of what my cpu is set at.
Sorry can you explain what you mean with that? MyOSMC has been updated to support the RPi3 and has under overclocking the “normal” values stored. So selecting “Normal” profile will remove the settings from config.txt
