Hello
I have same problem on my Pi3 (NOOBs) after last update
Here is the logs:
https://paste.osmc.tv/muceranajo
After some time (30 min) of playing recorded video first missing sound and after next few seconds also freezing picture.
There is no error message and sometime is possible to stop playing video and sometime is only SSH possible.
Could you help me please with any sugestion or if you need any information, please ask me.
Jan
Here is my top output when kodi is freezing again:
top - 21:39:56 up 14:30, 1 user, load average: 0.03, 0.03, 0.00
Tasks: 118 total, 1 running, 70 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.2 us, 0.8 sy, 0.0 ni, 99.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem : 748484 total, 21884 free, 301036 used, 425564 buff/cache
KiB Swap: 0 total, 0 free, 0 used. 389408 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
382 osmc 20 0 915728 282636 41368 S 2.3 37.8 55:06.55 kodi.bin
19338 osmc 20 0 5592 2528 1980 R 0.7 0.3 0:00.34 top
73 root 1 -19 0 0 0 S 0.3 0.0 1:05.86 vchiq-slot/0
240 root 20 0 0 0 0 S 0.3 0.0 0:03.89 brcmf_wdog/mmc1
675 ntp 20 0 7056 2636 2188 S 0.3 0.4 0:06.68 ntpd
1 root 20 0 25544 5076 3888 S 0.0 0.7 0:02.15 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.02 kthreadd
4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/0:0H
6 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 mm_percpu_wq
7 root 20 0 0 0 0 S 0.0 0.0 0:03.24 ksoftirqd/0
8 root 20 0 0 0 0 I 0.0 0.0 0:13.94 rcu_preempt
9 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_sched
10 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_bh
11 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/0
12 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0
13 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1
14 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/1
15 root 20 0 0 0 0 S 0.0 0.0 0:00.51 ksoftirqd/1
17 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/1:0H
18 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/2
19 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/2
20 root 20 0 0 0 0 S 0.0 0.0 0:00.24 ksoftirqd/2
22 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/2:0H
23 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/3
24 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/3
25 root 20 0 0 0 0 S 0.0 0.0 0:00.30 ksoftirqd/3
27 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/3:0H
28 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs
29 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 netns
33 root 20 0 0 0 0 S 0.0 0.0 0:00.06 khungtaskd
34 root 20 0 0 0 0 S 0.0 0.0 0:00.00 oom_reaper
35 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 writeback
36 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kcompactd0
37 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 crypto
38 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kblockd
39 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 watchdogd
40 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rpciod
41 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 xprtiod
42 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kauditd
43 root 20 0 0 0 0 S 0.0 0.0 0:04.54 kswapd0
44 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 nfsiod
67 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kthrotld
69 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 iscsi_eh
70 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 dwc_otg
71 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 DWC Notificatio
74 root 1 -19 0 0 0 S 0.0 0.0 0:01.97 vchiq-recy/0
75 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 vchiq-sync/0
Jan
Edit:
When I try to upload of logs I received:
osmc@osmc:~$ grab-logs -A
tvservice-client: Failed to download CEA cache in [vc_tv_hdmi_get_supported_modes_new]
Edit2:
After few enters and CTRL+C I received:
https://paste.osmc.tv/omudopesud
MOD EDIT: Please don’t use blockquote for pasting terminal output. Using </> preformatted text ensures proper formatting.
I think your problem might be unrelated. You’re running a Pi3B and most of the problems seem to be on Pi1Bs and a few Pi2Bs. Also, your CPU figures are, strangely, very low.
You’re overclocking some aspects of your Pi3, including the SD card:
gpu_freq=500
over_voltage=2
sdram_freq=580
over_voltage_sdram=5
sdram_schmoo=0x02000020
dtparam=sd_overclock=100
I suggest you comment these out and see if the issue persists after a reboot.
I think it is related. On previous freezing I had also high CPU usage, but it was possible stop the movie. In last case the Kodi not responding for stop movie command - maybe not working and it is reason for low CPU figures.
Overclocking of Pi is some tested config setting for HEVC by Millhouse on Pi3B+:
I´m using this also for Pi2 and it is working much better then without overclocking.
Part of these settings is depend the Popcornmix recommendation:
Jan
You’re free to continue with the overclocks but it doesn’t take much to disable them and see if it helps.
You’re on a Pi3B, not the plus version, and theMilhouse post was referring to a Pi3B+.
The second quote contains the line:
It’s an overclock, so not guaranteed to work on all Pi’s, but it works on a reasonable number
I Known, but I used the Popcornmix version since Jul 17 and Milhouse version since Aug 18 without big problems on Pi2, Pi3 and Pi3B+ also.
My problems was mainly with TV Headend.
Now I reverted to previous kernel and freezing is gone.
Jan
Hopefully the issue is now addressed
- Login via the command line
- Edit the file
/etc/apt/sources.list - Add the following line:
deb http://apt.osmc.tv stretch-devel main - Run the following commands to update:
sudo apt-get update && sudo apt-get dist-upgrade && reboot - Your system should have have received the update.
Thanks Sam for your hard job
I already updated to your test version
But I´m not sure if the result it will be correct, if I last evening revert the kernel version?
Anyway I will inform you about news after update
Jan
