If you don’t want to get NFS no matter what, but you’d just like to get a FSTAB mount working quickly, it might be good to switch to SMB FSTAB mounting at this point. With SMB you can use authentication and it might still give good enough throughput (but getting rid of the hassle with NFS, if this isn’t solvable in a timely manner, which it doesn’t seem to be):
And I thought, my NAS (WD MyBook Live) was a difficult setup with NFS… It doesn’t have any GUI configuration options for NFS, everything had to be done via SSH. But it looks like it was a lot less complicated than Synology seems to make the whole setup
I don’t want to imply that it doesn’t, just wanted to point @eriksdam to a different solution, if he’d want to choose to try something else… And if he’d not want to get NFS working at any cost.
Yup, ok… If @eriksdam is willing to keep trying a big longer. It might give some clues for future problems and maybe even for some adjustments of the wiki entry.
had a quick stab at SMB (which is what i started with before I posted here) but same issue: The files and folder themselves are found/recognised, but no playback.
I think I’ll call it a day, though, and post the logs tomorrow - thanks for your support!!!
I’m sure we are not far off getting this to work, but I agree starting again tomorrow is the way forward; taking a break from things, on return the way forward often shows its self. Will review the logs, when you’ve posted them tomorrow.
Thanks Tom.
@Chillbo thanks for the compliment. I’m no pro, just trying to learn as I go and like yourself help where I can.
I’m seeing 2 wired ports eth0 & eth1, so it looks like you are using a usb gigabit network adaptor; this seems to confirm it aswell:
Feb 04 22:37:23 osmc kernel: usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=6
Feb 04 22:37:23 osmc kernel: usb 1-2: Product: USB 10/100/1000 LAN
Could you please try playback using the onboard network port or the wifi.
You are probably aware your IP will change for test, for now please change the ip under Edit NFS rules to 192.168.1.0/24, as we had previously tried.
I don’t know if this helps, but I tried playing back a file on a Win 10 PC connected to the same setup in the same way - no problems, played back just fine.
Could you please provide logs, showing the failed playback on the onboard network port.
Thoughts without logs:
try a different network cable if possible
Try a different network port on router (more info about network setup would help. Is the vero4k straight into the router or is there switch or network over the mains plugs involved.)
I doubt the cable is faulty - the movie database get updated correctly = the connection is there.
The win 10 PC and the Vero are hooked up to the same switch and then to my Linksys Router, with everything connected with network-cables, no Power-LAN etc.
Tried WLAN, also changed the DHCP reservation - rebooted - SUCCESS!!!
Now, a smarter person would probably quit while he is ahead, but I’d still like to know what went wrong!!
