if i install plex, it doesn’t get start. is this because there is no decently support for plex in osmc?
is the rest using this without problems?
Plex has not updated their add-on to support the newer version of Python OSMC is currently running. The following thread outlines options to get it working either with patched versions you manually install or alternative Plex add-ons.
