Portable SSD Issue
I bought a 500GB Portable SSD and i tested with two difserents windows computers and works fine.
But at Vero 4K i can’t use. My Vero recognize and after a few seconds the device make an unsafe disconnection.
Very strange
Guess a power issue. Suggest to use a powered USB Hub
But SSD its a flash drive… don’t need to be powered… And why at windows computers it works ok ?
Oh sorry didn’t know that the SSD flash drives runs on love and air only.
Different hardware will provide different level of power on their USB ports
I would recommend externally powering it. This should solve the issue
I’m sorry but I disagree with you. It’s almost a pendrive and I’ve used it in others android box like Minix and Beelink that i have and works so fine.
Then providing logs would be next. Maybe we can see some issue with the device being properly recognized.
If you can believe this review it has a usb-c connection and I’m pretty certain that needs a powered hub
I already uploaded the log.
I tried to use a porwered hub and didn´t work. Now i´m really upset. Even with ssd ou normal external HD didn´t work,
Someone from Vero can help me ?
Where is the log? There is no link that I can see.
I´m sorry… is this address ?
https://paste.osmc.tv/jijimadiyi
That logfile was empty.
How can i upload without an sd card ?
Is your Vero connected to the network? You can just upload directly from the Vero.
Sorry… Now I think I did right
https://paste.osmc.tv/qijenotapi
Is this the drive?
/dev/sdb1            466G  173G  294G  38% /media/D8567D5E567D3E76
If so, yes it’s disconnecting for no apparent reason, and that normally means power. What powered hub did you try?
7 ports powered hub
I would still say it’s a power problem. Do you have another hub you can test with?
May 25 20:58:07 osmc ntfs-3g[1378]: Unmounting /dev/sda1 ()
May 25 20:58:07 osmc ntfs-3g[1378]: Failed to sync device /dev/sda1: No such device
May 25 20:58:07 osmc ntfs-3g[1378]: Failed to close volume /dev/sda1: No such device
The drive just seems to disappear with no reason. Also, have you tried a different USB cable (between both the drive and the Vero)?
Look… There something strange… I bought this ssd because my portable HD was making some noise and disconnecting. I thought the HD was the problem. But now I think that the USB ports on Vero is not ok.
I tried others usb cables.
I will try another powered hub. But sincerely I think that is my Vero, unfortunately.
Did you try the other port on the Vero just as a test? But if you were using the same hub, maybe it’s the hub that’s the problem.
