I access OSMC by SSH inside my home network with wifi and outside my home by no-ip. It works for me until a few days when suddenly the user and password when I acces outside my home doesnât work. I access wirh no problem by wifi, but outside when OSMC ask for user and password to logon I cant access.
Yes, the port is forwarding correctly. If I disable it the there is no connection. If I enabled, it connects but canât access because user and password is incorrect. If I acces inside my WIFI everything is ok.
Iâm really not sure how this can be an OSMC issue since there has been no change to SSH and you can still connect from wifi. It is certainly an issue with your portforwarding or no-ip config.
Login from wifi and run sudo journalctl -f. With that running try to login from remote and see if you get a connection request.
That will show you if your port forwarding works and might also show you what the problem is.
Sorry for delayed answer.
You need to go from main menu to âMy OSMCâ (if you don`t have it, you need to go to âProgramsâ where you will have it). Picture no. 1.
Open the App store, the shopping basket icon. Picture no2.
Select and click on âSSH serverâ. Picture no 3.
From left lower corner select âuninstallâ. Picture no. 4.
You will see in top right corner some activity and when its finished will show a message that its successfully uninstalled. Restart the RPi and do again the steps from above but you will have to select on step 4 from lower left cornet âinstallâ. Let rpi to install and after the message with succesfully install restart rpi. Try now to access through SSH.
