I’ve got an stk1160 video grabber as well … it isn’t supported well under the new kernels.
I’ve ordered an UTV007 instead, that one should work out of the box with newer kernels like OSMC is using.
@ r_pulp where did you buy the usbtv007 from m8 how much was it ? to get hyperion working I followed this guide but this was using raspbmc don’t know if it will work with osmc try this link https://christianmoser.me/how-to-ambilight-for-every-hdmi-source/ might be what your after
@ r_pulp it also says in the link if you read ahead that( I’d recommend a grabber with the UTV007 (Fushicai) chipset. It’s supported with OpenElec >=4.2.1 and features the best results for this purpose) but don’t know if it will work with osmc maybe you can try and let us know how you get on thanks
[quote=“r_pulp, post:12, topic:1282”]
you followed a guide to install the driver for the grabber?
[/quote]nope, I think @sam_nazarko put it in the kernel
