I’m also having difficulty with the proper settings for 4k movies.
I have my Vero 4k+ directly connected to my Vizio UHD 4k TV using a Certified Premium High Speed HDMI Cable, 4K@60Hz, HDR, 18Gbps, 36AWG, YUV 4:4:4 cable. Resolution is set to 3840x2160p, Refresh rate is set to 29.97. All other settings are default.
I watched “Transformers The Last Knight” 4k Amazon Prime movie and the colors popped and the dark scenes had a lot of contrast to make out little details. I hooked up my external drive to the Vero and played the same movie, here are the specs.
I know it could be from improper ripping of the movies (which I know nothing about).
The colors did not pop and it crushed a lot of the blacks where you lose detail and contrast. I’ve read a lot of other posts about the Vero not being able to handle 10bit and not passing all the HDR/UHD metadata for the file.
What should my settings be so I can get the best 4k picture now, until the Vero can handle proper 4k metadata?
The settings are oke. 422 is extra for certain tv’s. No need for now. 16-235 is mainly for tv’s.
Some users with LG displays may find that they need to set ‘Force 422 colour subsampling’ under Settings -> Display for reliable 4K playback.
Use limited colour range (16-235) instead of full colour range (0-255). Limited range should be used if your display is a regular HDMI TV and does not have a PC or other mode to display full range colour, however if your display is a PC monitor, then this setting should be disabled for correct Blacks.
Videos are actually encoded as 4:2:0. The player will generally upsample to 4:4:4 or 4:2:2 before sending the signal to the TV. Some TVs find it easier to handle 4:2:2.
Tried the 4k again and to be honest, the Bluray 1080p has a better picture. The 4k just loses colors and is washed out. Now if I go into the videos settings while the movie is playing and adjust the brightness and contrast I can get better quality, but i would have to do this every time i watch a 4k movie. One of the main reasons besides being able to play H265 format movies was to be able to also play the 4k movies too. It seems like the Vero 4k+ just isn’t ready for 4k yet. Hopefully soon.
