These are streams from TVHeadend 4.0.7 (running on separate hw). The problems seem to happen only with streams recorded from Finnish TV via DVB-T, Swedish TV over DVB-T is fine as are Swedish channels over DVB-C. It has always been this way AFAIK.
This is what happens:
When you watch, the info on programme length and such are wrong:
If you try Fast-Forwarding it will sometimes forward, but when you hit “P” it puts you at the start, same if you try typing in a time or using the arrow keys.
When you are searching and seeking, you are probably just seeking via the Kodi buffer.
I still don’t believe TVHeadend does time shifting as of standard yet. It didn’t when I last checked. If it does, then this matter is still probably better served on the TVH forum
OK. I have posted the question there (link in message above), but naturally, what bugs me is that some streams are OK, others are not. Think that I could see anyhing in the logs, or on the screen when I press “o”? Do not exactly know that all the values mean there…
@sam_nazarko , I don’t think @AndersG refers to time-shift. As far as I understand these are finsihed recordings that he is watching.
@AndersG my assumption is the recordings are bad. Can you seek thru them from any other device (e.g. PC with VLC)? What does mediainfo report on those files?
I might be wrong, but my understanding is that “timeshift” is where you watch a recording, whilst recording. This is not the case here (even if it is a desireable feature). We are watching stuff recorded days ago.
I did not have time to check on a PC, but I did test on VLC on android and there I could not position on any of the streams, ie tried to go to 10:30 and nothing happened. I was able to fast-forward though and stop and end up in the correct place. This does not work on the problem streams on OSMC. On OSMC, hitting “p” whilst on say 4X either puts you at the start of the stream or exits the film and puts you back in the menu.
When you say “mediainfo” do you mean on OSMC or on the Linux box running TVH?
@sam_nazarko, if you look at the screenshots above. From where does OSMC get the values it is displaying? say time/endtime?
tvburk:/home/dalton/Videos # mediainfo "Ommelten valinen aika-1.ts"
General
Complete name : Ommelten valinen aika-1.ts
Format : MPEG-TS
File size : 1.26 GiB
Duration : 55 min
Overall bit rate : 3 261 kb/s
Video
Menu ID : 201 (0xC9)
Format : AVC
Format profile : Main@L3
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 55 min
Bit rate : 2 712 kb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Scan type, store method : Interleaved fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.262
Stream size : 1.05 GiB (83%)
Color range : Limited
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 4
Duration : 55 min
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Compression mode : Lossy
Delay relative to video : -784 ms
Stream size : 152 MiB (12%)
Text
Format : DVB Subtitle
Codec ID : 6
Language : Finnish
Menu
Duration : 55 min
List : 513 (0x201) (AVC) / 529 (0x211) (MPEG Audio) / 6636 (0x19EC) (DVB Subtitle, Finnish)
Language : / / Finnish
Service name : YLE Teema
Service provider : Harmonic
Service type : digital television
tvburk:/home/dalton/Videos # mediainfo "Var stora karlek-1.ts"
General
Complete name : Var stora karlek-1.ts
Format : MPEG-TS
File size : 1.72 GiB
Duration : 1 h 5 min
Overall bit rate : 3 765 kb/s
Video
Menu ID : 1302 (0x516)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Format settings, picture structure : Frame
Codec ID : 2
Bit rate mode : Variable
Bit rate : 3 320 kb/s
Maximum bit rate : 6 000 kb/s
Width : 720 pixels
Height : 576 pixels
Active Format Description : Full frame 16:9 image
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Scan type : Interlaced
Bits/(Pixel*Frame) : 0.320
Stream size : 1.52 GiB (88%)
Audio
Format : MPEG Audio
Codec ID : 4
Bit rate : 256 kb/s
Delay relative to video : -280 ms
Stream size : 120 MiB (7%)
Language : Swedish
Menu
List : 1639 (0x667) (MPEG Video) / 1638 (0x666) (MPEG Audio, Swedish)
Language : / Swedish
Service name : SVT1 ABC
Service provider : Sveriges Television
UTC 2016-07-06 09:00:00 : sv: / sv: / social/political issues/economics / / 00:40:00 / Running
UTC 2016-07-06 09:40:00 : sv: / sv: / movie/drama / / 01:00:00 / Not running
UTC 2016-07-06 10:40:00 : sv: / sv: / show/game show / / 01:00:00 / Running
UTC 2016-07-06 11:40:00 : sv:The Artist / sv: / movie/drama / / 01:40:00 / Not running
There may be problems with the stream. A remux might fix the problem. If you’re watching these files recorded, rather than live, and having a problem, then this would suggest a problem with the files themselves.
I can try and yes, I can easily provide a file. I guess I should try first to play it as a file, instead of via TVH. Ie there might be differences if it is accessed like a stream or read as a file.
I have one 193Mb file, three minutes worth of a childrens programme. This file acts exactly the same whether I watch it as a htsp stream from tvh or if I read it as a file over NFS. Ie:
When fast forwarding, the status line shows the same time for start stop
If I hit 1:00 or 2:00 to seem one or two minutes into the film, I am deposited at the beginning.
How do I get this file to you an donly you for testing purposes? I do not want to put it on a publicly accessible webserver since it is probably copyrighted material.
This file does FF correctly though, possibly because it is so small, in the past FFing over 2x generally results in ending up at the begining or exiting altogether.
How should I upload? I cannot here: “Sorry, the file you are trying to upload is not authorized (authorized extension: jpg, jpeg, png, gif, ico” so I put i here: http://www.pedago.fi/Murut_ja_lurut.ts
Please say so when you have downloaded so I can delete it.
