Hello, I recently had my Zotac mini HTPC with LibreElec on it die, and I took a chance on the Vero 4K…Kodi out of the box was pretty appealing.
Unfortunately, I’ve found myself hunting for instructions on how to install LibreElec on the Vero.
But before i head down that road, I figure i’ll try to get some help here first. My expectation, based on OpenElec and LibreElec was that my BD Remote would just work once I got it paired. Out of the box, i used the little included remote to quickly get my BD remote paired and thought i was done.
Unfortunately, as has previously been reported, only certain buttons are working (Play, Stop, Navigation) but other important ones like Vol Up, Vol Down, Mute, etc don’t work.
Like a previous poster, i tried the keymap add-on and managed to capture Rewind (61636), but all of the others I try don’t even register in that add-on.
I’ve reviewed and attempted the solutions below, without much luck.
and:
https://kodi.wiki/view/HOW-TO:Set_up_PS3_BD_Remote - which is 3 years old and full of broken links.
I’m running the latest version of OSMC and my remote is a Gen 1 PS3 BD remote.
I would be willing to manually build a remote.xml if i could capture the codes the remote is sending…if only i knew how.
Please let me know if anyone has any suggestions.
