I’ve heard good things about the community and the player. Hoping you can help before I make a purchase decision.
I understand 3D MVC support is forthcoming - is this still the case?
Can you output to the native colourspace of the original file being played back?
Can you output to the original resolution of the playback file?
Does the official Plex addon work as it does on the Shield?
Number 3’s scenario would be if I was playing a 576i or 480i MPEG2 DVD file I’d much prefer the player to output at the original res and let the TV do the rest. The Popcorn Hour VTEN is very good at this. I know you can set to 1080p to avoid upscaling all content to 4k but worried about the quality of SD content.
Yes – however: we recommend running the GUI at 1080p; and then OSMC will switch to 4K if warranted (i.e. if your display supports 4K and you are playing 4K material). For a DVD, it will be output at 1080p unless you manually change the resolution of the GUI to 480p/576p as well. If there was enough demand for this, we could look at implementing this feature.
Yes – I don’t remember if the Plex add-on still requires Plex Pass, but that’s something you may want to check.
