Hi all, I recently updated my raspberry to osmc running kodi 17, but I have some major issues since then:
-it keeps losing settings, even if I don’t reboot. For example, randomly yatse stops working and I have to check again the option for enabling external application to control, or the time format for the clock keeps changing to 12h am-pm from 24h format.
-wifi performance dropped with my nano edimax dongle
Was it raining when you did the upgrade to v17?
I don’t know when I got back from work I found the prompt with the upgrade ready to get installed. Why did you ask me?
Thanks! I’ll try now
Well you wrote that wifi performance dropped
, as the last update didn’t changed any packages related to the network the update is unrelated to wifi performance as much as the weather is to your update.
