Same SD Card, power source and everything else that I have been using all along for Raspbmc and now OSMC. Fresh install on the card when testing update.
Does adding gpu_mem=16 to the config.txt file on the SD card after imaging before inserting the SD into the Pi for the first time help (i.e. before you run the installer)?
I’ll also look at improvements to reduce the target installer’s memory consumption. For now it would be great if someone who’s had this problem to test this image:
That new image didn’t work. After I flash it using the windows installer, I put it back into my Windows PC and there are only 3 files (filesystem.tar.xz, kernel.img, preseed.cfg). No config.txt, etc. When I put it in my RPi it wouldn’t boot, I just got the red power light, no green/activity lights.
I have flashed the RC build from yesterday, added gpu_mem=32, and it looks to be working now (installer is around 75%).
Windows installer (downloaded at time of RC release)
Windows
SD - tried 3 different cards, saw no difference in results between the 3.
Pi Model B 256MB.
Power supply is the RS one, which I know isn’t the best but has worked fine in RaspBMC. Also tried a 1A PSU and different cable and got the same results.
I’d also like to add that I also had this issue with my Pi B 256MB with OSMC RC. There were no issues with A4.
Standard image would stall at 10% mark.
Adding gpu_mem=32 to config file has allowed it to install.
However, the main menu screen, the text is huge comapred to Alpha 4. Is this intentional? Previously, all the option (Videos, Music, Power etc) all fit on the screen. And now they’re massive and only a few fit on screen and you have to scroll to see the others. Much prefer the old way if this is a change, perhaps theres an option?
