After the most recent upgrade my RPi2 boots to sad face.
My guess is that either incompatibility with an addon or the skin
mv .kodi/userdata/guisettings.xml .kodi/userdata/guisettings.xml.backup
mv .kodi .kodi.backup
Means just doing step 1 didn’t help?
If that is the case then you only can try to check one addon after the other.
Many of the addon’s you had installed can not be supported on this forum so you are on your own.
Please see this link here FAQ - OSMC Forums
