https://paste.osmc.tv/tiyeferiwa this log including network wifi AC tentative
I disconnected the dongle so I can upload le the logs
massive : [ 470.761594] receive cmd msg fail(-71)
whatâs the output from
connmanctl services
connmanctl technologies
and
connmanctl services <wifi-service-name>
where <wifi-service-name>
is taken from the output of first command.
*AO Wired ethernet_b827eb4ab194_cable
*A dd-wrt-5-B wifi_000000000000_64642d7772742d352d42_managed_psk
dd-wrt-5-A wifi_000000000000_64642d7772742d352d41_managed_psk
/net/connman/technology/wifi
Name = WiFi
Type = wifi
Powered = True
Connected = False
Tethering = False
/net/connman/technology/bluetooth
Name = Bluetooth
Type = bluetooth
Powered = False
Connected = False
Tethering = False
/net/connman/technology/ethernet
Name = Wired
Type = ethernet
Powered = True
Connected = True
Tethering = False
Type = wifi
Security = [ psk ]
State = idle
Strength = 50
Favorite = True
Immutable = False
AutoConnect = True
Name = dd-wrt-5-B
Ethernet = [ Method=auto, Interface=wlan0, Address=00:00:00:00:00:00, MTU=1500 ]
IPv4 = [ ]
IPv4.Configuration = [ Method=dhcp ]
IPv6 = [ ]
IPv6.Configuration = [ Method=off ]
Nameservers = [ ]
Nameservers.Configuration = [ ]
Timeservers = [ ]
Timeservers.Configuration = [ ]
Domains = [ ]
Domains.Configuration = [ ]
Proxy = [ ]
Proxy.Configuration = [ ]
mDNS = False
mDNS.Configuration = False
Provider = [ ]
Letâs try this with the dongle plugged in. (SSH via cable and copy/paste all screen output).
connmanctl
config wifi_000000000000_64642d7772742d352d42_managed_psk --remove
scan wifi
agent on
services
connect wifi_000000000000_64642d7772742d352d42_managed_psk
enter passphrase if prompted, then quit and run ifconfig
. (Iâm assuming the service name is unchanged.)
Passphrase? whatâs? sorry I guess itâs a dumb question. You mean my ddwrt password?
Yes, the wifi password.
connmanctl
connmanctl> config wifi_000000000000_64642d7772742d352d42_managed_psk --remove
connmanctl> scan wifi
Scan completed for wifi
connmanctl> agent on
Agent registered
connmanctl> services
connmanctl> connect wifi_000000000000_64642d7772742d352d42_managed_psk
Agent RequestInput wifi_000000000000_64642d7772742d352d42_managed_psk
Passphrase = [ Type=psk, Requirement=mandatory ]
Passphrase? MY_WIFI_PASSWORD???
Agent ReportError wifi_000000000000_64642d7772742d352d42_managed_psk
connect-failed
Agent request cancelled by ConnMan
Error /net/connman/service/wifi_000000000000_64642d7772742d352d42_managed_psk: Operation aborted
Can you post the log showing what happened during these commands?
ANother question to @sam_nazarko. Whats is the little button of the dongle on the side noted âwpsâ?
Itâs for automatically connecting. Unfortunately security vulnerabilities were discovered in WPS, so we donât recommend using it.
You wrote back on 27 May:
So I assume you have 4 OSMC dongles, 4 Pi3s and 4 official 2.5A RPi power supplies.
Just to eliminate the possibility of it being a hardware issue, could you:
Please also run paste-log /lib/firmware/mt7610u_sta.dat
and post the URL.
https://paste.osmc.tv/cabeyafewo
I tested individually each hardware power supply, hub, raspberry, dongle wifi (ok on windows 7 and 10), everything is working
Looking back over this thread, I see that you were using channel 36 and a channel width of 80 MHz on the router. Channel 36 only supports 20 MHz, so try that combination.
ddwrt 20mhz and channel 36 AC only mode, same problem
Status: No internet
Channel 36 / 80 MHz was clearly incorrect, so at least thatâs one thing weâve corrected. But without new logs, I have nothing to go on.
1 Please run the following:
sudo rm -rf /var/lib/connman/wifi*
connmanctl
scan wifi
agent on
services
then enter your passphrase when prompted. If it fails to connect, post logs.
2 Move the Pi to a location close to the primary router and run the following (basically a repeat of 1):
connmanctl
scan wifi
agent on
services
connect wifi_000000000000__xxxxxxxxx_managed_psk
where xxxxxxxxx is the code for the primary router. Enter passphrase when prompted then post logs.
3 As requested on 29 August, please say what channel / channel width you use to connect between the repeater and the primary router.
1/
https://paste.osmc.tv/etocohocuk (/lib/firmware/mt7610u_sta.dat)
https://paste.osmc.tv/yeculadeju
I removed the dongle to upload via ethernet
ddwrt AC-mode only channel width 80mhz & channel 64 (listed as conform in norm)
2/
https://paste.osmc.tv/azaqijopiz (/lib/firmware/mt7610u_sta.dat)
https://paste.osmc.tv/ehepibaduq
well connected on primary router (wifi N) and can upload logs via wifi
3/ wireless mode ârepeater bridgeâ
wireless network mode âNG-mixedâ
but I donât set channel width / channel, I guess itâs automatic settings, just set the primary router passphrase
Hope enough logs
Thanks again to everybody for supports.
I think weâre making progress.
First, I see you set the AC channel on the router and on the dongle to be channel 64. I did a bit of reading up on DD-WRT and, though channel 64 is only 20 MHz wide, DD-WRT will find the nearest 80 MHz channel if you specify 80 MHz channel width. Thus in the log we see this:
Sep 15 15:19:18 chambreparent wpa_supplicant[378]: wlan0: Trying to associate with e8:fc:af:fe:a9:d0 (SSID='dd-wrt-5-B' freq=5320 MHz)
Sep 15 15:19:18 chambreparent kernel: ==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=64)
Sep 15 15:19:18 chambreparent kernel: PeerBeaconAtJoinAction(): HT-CtrlChannel=64, CentralChannel=>;62
Sep 15 15:19:18 chambreparent kernel: PeerBeaconAtJoinAction(): VHT->center_freq_1=58, CentralChannel=>58, vht_cent_ch=58
Sep 15 15:19:18 chambreparent kernel: PeerBeaconAtJoinAction(): Set CentralChannel=58
Sep 15 15:19:18 chambreparent kernel: AdjustChannelRelatedValue(): Input BW=2, rf_channel=58, vht_bw=1, Channel=64, vht_cent_ch=58!`
The dongle is looking for a connection on channel 64 (5320 MHz) but the router has its central channel set to 58. Therefore I think it would be better if you left the channel to its default value on the dongle and then let it scan for available channels on the router. For now, I would also suggest you stick with a 20 MHz channel width. You can try to increase it once we have a working connection
Having successfully negotiated a connection with the router, it needs another 9 seconds for DHCP to allocate an IP address, 192.168.1.23, which is very slow:
Sep 15 15:19:28 chambreparent connmand[238]: wlan0 {add} address 192.168.1.23/24 label wlan0 family 2
Sep 15 15:19:28 chambreparent connmand[238]: wlan0 {add} route 192.168.1.0 gw 0.0.0.0 scope 253 <LINK>
Sep 15 15:19:28 chambreparent connmand[238]: wlan0 {add} route 192.168.1.1 gw 0.0.0.0 scope 253 <LINK>
Unfortunately, the dongle then disconnects from USB.
Sep 15 15:22:59 chambreparent kernel: usb 1-1.3: USB disconnect, device number 5
It was suggested in a previous post that adding the line
BackgroundScanning = false
to /etc/connman.conf
(and rebooting) can sometimes help. Since I think you performed a full reinstall, please make sure you added this line to the new system.
Second, I see that you had no problems connecting to the primary router on 2.4 GHz, channel 6. You will also see that in the configuration file you left the Channel=0
and it still connected successfully.
Third, just to clarify one point, the transmission speed to/from the internet and any device connected to the primary router will run at the speed of the âN/G-mixedâ link.
According to this link Basic Wireless Settings - DD-WRT Wiki
VHT80, channel 64 should be ok
I will have a try with channel 58 so and another try with 0 for auto scan
I will add BackgroundScanning = false too
According to that link VT80 should be ok wilth 64+LL
The link also says that VT80 should be ok with 36+UU, whereas you were using 36+LL
(lower lower) on the screenshot, though in a later log it looks like you changed it to 36+UU without telling us.
However, to keep things simple, please use only a 20 MHz channel width for now. And also plug the dongle directly to the Pi.
