That’s good – or at least better than the device having stopped working!
You can grab them here;
Ordered one - thanks
Do you happen to know what causes them to break at all? (fixed on the Vero5 power supply?)
Power supplies will degrade over time for any peripheral, particularly if you run it 24/7.
There are some improvements with the Vero V power supply but the failure rate for Vero 4K + is very low and well within normal parameters.
A post was split to a new topic: Red light on, Vero 4K doesn’t start anymore
