Hi @sam_nazarko and all…
Sam, let me set this straight right from now…
I don’t want to start a war here and, while it is true that we are on opposite sides of the fence, what follows is written without any intention to offend or detract from the fact that OSMC’s products are very good and that your support is obviously at an high standard, usually.
I just believe that, in this very special case, users haven’t been told the true story at the beginning, to start with, and some of them, myself included, are being let down straight away.
But, even if it is a single unfortunate situation, let me say it casts a shadow on an otherwise great product/company.
Let’s go…
No wonder, Sam… Would you expect differently?
Also the many that, for several reasons, still haven’t realized they have a faulty unit are not complaining… or the ones that have accepted the replacement (External) dongle as a quick solution.
Hopefully you can appreciate our attention to customer service responding on Christmas Eve.
There is pretty much no downtime currently and it’s crazy here.
Of course I do, and I wish all the very best for this holiday season and for the new year!
We don’t know if an issue is inflicted by you when you open a device.
Oh, well… It’s a simple device, in the way it is made… A snap case, a single board… The user, knowing there is a Receiver USB Dongle inside decides to open it because original warranty is expired (12 Months only… if it was EU, it would have been 24 Months and I wouldn’t have opened the unit!) and wants at least check if unplugging/replugging the USB Dongle in the same/in another USB port solves the problem. Then decides to resont to your support and, eventually, you get the unit in your lab. You check it and, if you see signs of damage possibly related to users’ actions, you take appropriate measures. But if the user didn’t break anything and if the fault you find is something you already know is happening to “some” units because of marginal/poor design, well… I do think you still owe that customer some special attention.
If you open the device, you forfeit your warranty and any free repairs. Sorry but I will hold firm on this.
And here we have, in my opinion, another problem, Sam…
You say, in another post above:
It does say in the supplied booklet that you shouldn’t attempt repairs on the equipment yourself.
I have the booklet, and it reads, literally:
Troubleshooting
You may experience some difficulty in operating your Vero or getting it set up. We have assembled a list of common issues.
Do not attempt to repair the device yourself, and do not open the unit as there is a risk of electric shock.
See? You explicitly warn users that opening the device poses a risk of electric shock, and you obviously don’t want to be held liable for that, but I see no explicit information to users, in any part of the supplied documents, that opening their units will void any residual right to proper support!
I know we’re walking on a thin line, Sam, but since you mention the booklet, you should know what’s written in there!
It’s nothing to do with the UK’s position with the EU / Brexit. I am not sure where that was brought up at all.
Not your fault, of course, but shipping to/from UK is not the same as shipping to/from any other UE Country… Cost of shipment is higher and there is considerable hassle with customs/taxes for the occasional shipper. But this is not relevant to the core problem, I agree.
Me: a fault that, again, was EMBEDDED in the unit right from the start!
You: If you genuinely believe this, then the issue should have occurred from the start and you have rights you can exercise regarding this.
Ok… I’ll rephrase: the underlying cause of the issue (Marginal/Poorly designed circuits or selected parts!) was in the unit right from the start. The fault was not present right then, but appeared as soon as the (Not so special) conditions aligned unfavorably. And, when it happened, it could also remain undetected, but still present, depending on users configurations/use cases. A “latent defetct”, in simple words!
The onus is on you to prove that there is a poor design case.
True, Sam… and as a matter of fact I don’t have any way to prove that but, I’m reasonably sure, everyone reading this thread will see where is the original problem.
You even changed part of the circuit involved, as a countermeasure to what you, undoubtedly, also had realized was happening.
Marginal/Poor design is inherently admitted, the way I see it.
The facts are as follows:
- If you have a problem with Vero V, we will put it right within warranty
And, from another post of yours, Sam:
If the device is in warranty, they will receive an immediate replacement free of charge.
This is the only situation you took appropriate and due action, in my opinion. You had to because of warranty commitments, obviously…
If there is a problem outside of warranty, we will do our best to remedy this and there are several options available to you
Let’s see what these options are:
If the device is out of warranty, but has not been opened, they can choose the best option for them:
They can order a replacement receiver which can be attached to a side port on the box. This is most convenient as delivery is quick and the device does not need to be returned
And this DOES NOT SOLVE THE ISSUE, as it leaves the customer with a partially faulty unit and one less available USB port. But you present that as the best option as it is quick and hassle-free.
They can return the device for replacement, but this can take up to 20 weeks (we aim for less). Due to legal requirements, shipping needs to be covered by the customer.
This would be the proper action for everyone having the issue, of course, but it is the most expensive one for you and you DISCOURAGE users to freely choose it, warning users it would take 20 Weeks (TWENTY WEEKS! Compare that with “IMMEDIATE REPLACEMENT”, if covered by warranty!) and they would have to carry the costs and hassle of a shipment!
For some customers that order additional devices, the replacement can be shipped back with the new order.
So, if users were to order new devices, a replacement is miraculously available in short time!
I really wonder why the only proper, yet expensive, action is the slow and uncomfortable one.
Clever wording, Sam… I bet you had close to zero (Faulty) boxes returns…
Finally:
If you have a problem with the remote controller or USB port, we will solve this for you one way or another if you are the unfortunate 3 in 1000
Oh… I’m pretty sure, again basing my impressions on experience, as I don’t have facts, that the numbers may quickly climb from that (apparently) meager 3/1000.
Otherwise you probably wouldn’t have been so worried of a potential mass return of units with a faulty USB circuitry, wrecking havoc in OSMC statement of account.
But, by know, it’s clear to me and I believe to those in my same position also, that we’re beating a dead horse here, as there is ZERO will to admit that some of the units, probably many more that what is already evident here, were ill-fated since they were born. And I can understand your reluctance, in your shoes, as doing so would potentially open the proverbial Pandora’s Vase.
So, I believe all cards have been played and are on the table… I call it a day.
I’m not happy, of course, and I feel let down enough to be very doubtful about future purchases from OSMC, but it has been an interesting chat… thank you for keeping up with my long posts, Sam.
There is just a final curiosity I have, because at this point I have nothing more to lose…
In rare circumstances, the temperature generated by the set top box during long term operation combined with external usage environments is too high. This can cause the USB port to not be recognised. This is repairable via an air-gun.
And, from a previous post that was quickly damped:
Sam: 21 Nov
I don’t think dtech needs support because he soldered his own solution
@dtech said:
Yes, I had a workaround to overcome the internal USB issue, but since it would obviously void the warranty for other users, I didn’t even think of publishing it.
Well… I already have an idea of what I want to try and see if it fixes my ports, but would appreciate more info about both statements, as I may want to try and revive my unit, if possible.
While I understand that the information probably doesn’t belong here “in the wild”, I hope in some DM or the like.
Have great holidays, everyone!
Joe
