Okay. When you post logs we might have some clues as to what is going on.
Hi Sam,
Perhaps this one might need a new post but I’ll ask here anyway, and will remove if required.
After I noticed that the update broke my remote, I switched the memory card from my other rpi (not had update - and probably wont get it) to find that the remote still didn’t work. The only difference I can see is that the Firmware was updated, which may be related.
[quote=“sam_nazarko, post:5, topic:37293, full:true”]
The full dmesg output would be more helpful. [/quote]
https://paste.osmc.tv/unupiwedob.md
The checkbox for Disable RC6 is not checked.
I’ve added “service eventlircd restart” for good luck, but unfortunately inserting those kernel modules does not help.
Here are my grab-logs for good measure: https://paste.osmc.tv/eduxiperat
Thanks. I’m looking in to this.
Can you try checking for updates and installing them and letting me know
if this resolves your remote issue?
It might take 25-30 minutes for the update to reach you.
I have installed the update, now running “OSMC May 2017 2017.05-2” but the situation did not change. Both the original remote and Logitech Harmony do not work. The USB keyboard still works fine.
I experience the same issue, did the following tests with various remotes:
NONE of the above is working at all
It seems that all IR remotes are affected
Please fix this issue asap, updates are supposed to
improve things not destroy them.
Indeed.
It would help if you provided the necessary information to resolve your problem. We are not sure
what hardware you are even using OSMC with.
You can of course reinstall / downgrade if needs be.
Sorry, I didn’t realize that I didn’t mention my device.
It’s a Vero 4K.
Not sure what else info you might need,
I have tested 5 IR remotes.
If I can help any further I’ll be happy to do so.
I believe this issue issue has now been resolved. You can update your device to receive a fix for this problem.
As you say, updates are meant to improve things, but occasionally there can be regressions. I’m grateful for your patience.
I have made a note on your account and applied a credit for any future order. Please let me know before you place your next order.
Thanks Sam! My IR remote is now working gain. My original RF remote is still dead, but I think that is a different issue. I’ll open another thread for that.
