I’ve had my Vero 4k on the sidelines for quite some time and was thinking on repurposing it with a desktop linux distro. I’m aware of few arm64 distros but not how compatible they are with this specific SOC. Any thoughts?
Has anyone had any luck installing a debian, manjaro or something else?
Ok, but Vero4K uses a 32bit user-space and 64bit Kernel-space, so your solution is not always practicable or the best…
In my case I stopped to use Vero4k as Mediacenter and I use it for Home Automation (with HomeAssistant) but this limit of 32bit user-space is very boring because I cannot install 64bit version of Database or Python so all datetime/timestamps will be broken in one decade when a 32bit cannot handle Dates anymore.
I’ve tried using a 64bit toolchain and running on installations “inside” it but it’s very annoying and hard to use/maintain.
Will “old” Vero4k (without the Plus “+”) updated as well? (I bought it many years ago and I updated to Kernel 4.9.269 using an “unofficial” repository/procedure to have newest APT packages and all is working fine)
Just installing a 64bit toolchain it’s not sufficient to run all installations and binaries on that 64bit. Any “apt install” command will run in the normal 32bit and the same happens while running Python or other binaries.
It’s passed many time from when I dismiss this toolchain solution, but I remember I should used special command/prefix to execute an Unix command “inside” that 64bit toolchain environment/folder instead of 32 and in that way all installations and binaries where installed in toolchain’s default folders and can be use from all 64bit binaries.
Unfortunately running 64bit Python VirtualEnv scripts inside a toolchain (using that command-prefix behavior) is very hard and I surrended after many days of tries.
Maybe “now” the 4.9.269 Kernel is the normal one, but at that time (many years ago) it was stucked at 3.14 and update to 4.9 was possible only by adding a (beta?) repository before running an APT upgrade.
Docker is the fastest solution to bypass many problem, but I don’t use it if I don’t have to.
It has obliviously an overhead, adds harder complexity for Storage/Data to let persist them across container runs, unusual hardware is harder to connect to it when binaries need it (I.e. an USB antenna for Zigbee/ZWave networks), run a single command (expecially in python virtual env) from “outside” could be a pain in the… because it requires a complex command and it’s too waste of time everytime I need to exec something.
With help I was able to install Armbian on my Vero 4k. It’s not a normal installation, because u-boot doesn’t read the Armbian kernel and dtb by default. I had to UART the device to find out what exactly happened and change the boot environment. For installation UART is not needed, although messing with the boot environment without access to UART is risky.
Disclaimer: this is not an official Armbian installation method and also not supported by OSMC.
Proceed at your own risk and consider to keep OSMC with these very useful options first:
My personal motivation for getting Armbian to work is to have V4L2 from the newer kernels. AFAIK this is not possible with the provided Docker solution. Also, I wanted to learn about Linux/ARM/u-boot/soldering etc.
