Ive recently been playing 4k files, but if i open the next video 1080p before i stop the 4k, the resolution sticks at 4k and is juddery until i stop then start again then it changes to 1080p
Doesnt the option for sync START/STOP update when you open a new file?
Without logs its hard to advised why, but I would guess you have the set the gui resolution higher than 1080p; which isn’t recommended. If not:
reproduce the issue
Starwars 4K83 (video was choppy but thats just when logging enabled), then switched to a recording of Bear grylls (still in 4k format) stopped and started file switchs to normal HD
Does changing to adjust refresh rate to always, fix the issue?
Also stupid question, but what do you mean by switch? Are you stopping the 4k first and then starting the 1080p or Starting a 1080p when a 4k is already playing?
Can you please reproduce going from 4k to an actual 1080p file, the Bear is 540p. I’m not saying to 540p shouldn’t work, just would like to see what it actually does with 1080p.
I think if you set adjust refresh to always and tried this with content that is 1080p, you will get the wanted result. For everything else you would be better off, stopping the currently playing 4k content and then starting the less than 1080p content.
I think the issue is being caused by white-listing. But I don’t think you are going to able to white-list resolutions less than 1080p and get the correct refresh rate. More details can be found here:
If I’m right, this will be affecting kodi across many platforms and not something that osmc is going to be easily or at all be able to fix.
He is not using a whitelist. I can reproduce the issue as described with refresh set to on start/stop. I cannot reproduce with the refresh set to always and that works as it should regardless of if it goes from playing 4k to HD, or 4k to SD. I would advise the OP to stop their playing video, go to settings>player>videos>adjust refresh rate> and set that to “always” then test it again.
When to adjust refresh rate is set to start/stop - Kodi is getting to the refresh rate of the previously playing file and not checking again.
When set to always - I thought it was to do with 540p & 720p not being in the default whitelist, but apparently this isn’t the case. I think we need to dig further.
I’m not quite sure why this isn’t working, @darwindesign is indeed correct:
Matching to the default white-list is failing, when switching back to resolutions less than 4k; but when stopping playback and starting it again, matching to the default white-list works.
This will need to be looked in to. For now the easy thing will be to just stop and start, rather than switching. You could have a go a setting white-listing, as described in the how to posted by @angry.sardine. You need to be very careful with this, as kodi will only playback resolutions & refresh rates in your whitelist, regardless of whether the tv supports it.
I know, I meant more if you don’t select one and you have content that needs it or if your like me where I haven’t white-listed anything under 1080p, due to refresh rates.
