Retroplayer (Emulators list)
wierd i dont get that when i try. which system are you running it on ?
I’m using QuickNES on a Pi3B+.
I’m running the Elite version downloaded from Ian Bell’s own Elite website,
perhaps it is a problem with that version.
It looks like the “black screen” problem (GLES bug) in Stella and many other emulators have been solved, at least in the sources: RetroPlayer: Fix black screen for RGB emulators on some GLES platforms by garbear · Pull Request #16421 · xbmc/xbmc · GitHub
True, but it has yet to be merged and then backported to Leia.
All checks have failed
fails when building so its not complete yet. ive pinged gmc to keep an eye on it once it passes it will be merged to the test builds.
Solves the long outstanding GLES black screen bug :tada:
added notes feel free to report back if they dont work for you want feedback on this
the patch itself :slight_smile:
getting atari games to run however seems to be an challange bit glitchy and laggy and so far it seems to cause issues within kodi so its gonna be reverted and reintroduced in a later date when it done.
I can only get one controller to play games on the genesis plus gx emulator, any thoughts?
Osmc is happy with both my usb snes controllers, as is the snes emulator, but the genesis one only sees one controller.
Rpi 3, osmc running Kodi 18.3, genesis plus gx 1.7.4.4
Thanks!
according to the guide from kodi forums it should be as simple as plugin it in and then setting it up as player 2
They both work plug and play with kodi, and with the snes emulator, but not with the genesis emulator. Is there something I missed @Toast?
gonna see if i can get it working havent tried any 2p games.
