Retrosmc Launcher issues
I installed Retrosmc and all seemed good. I tried to setup the launcher but it only seems to restarts osmc.
I can run Emulationstation from SSH and it works like a charm, just not with the launcher.
Anyone with this issue?
Robert
Try the solution from original HowTo: [HowTo] RetroPie and OSMC: Retrosmc - Retrogaming on OSMC - #1454 by RJ45
Thank you so much for the link. It worked perfectly.
