Zoltan
5 February 2015 09:16
#1
i just got my RPI2 yesterday (yessss ) and installed OSMC alpha 4 on a usb stick,
it runs very very fast (thanks) but i cant get hyperion working on it.
cant run the install script on rpi2
got this error:
osmc@osmc:~$ sudo sh ./install_hyperion.sh
Downloading hyperion
converted ‘https://raw.githubusercontent.com/tvdzwan/hyperion/master/deploy/hyperion.tar.gz ’ (ANSI_X3.4-1968) → ‘https://raw.githubusercontent.com/tvdzwan/hyperion/master/deploy/hyperion.tar.gz ’ (UTF-8)
–2015-02-05 10:21:02-- https://raw.githubusercontent.com/tvdzwan/hyperion/master/deploy/hyperion.tar.gz
Resolving raw.githubusercontent.com (raw.githubusercontent.com )… 185.31.17.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com )|185.31.17.133|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 7703220 (7.3M) [application/octet-stream]
Saving to: ‘STDOUT’
2015-02-05 10:21:05 (4.64 MB/s) - written to stdout [7703220/7703220]
Installing startup script in init.d
insserv: warning: script ‘K01hyperion’ missing LSB tags and overrides
insserv: warning: script ‘hyperion’ missing LSB tags and overrides
Did someone manage to get working hyperion on it? (rpi2)
how?
thank you
Zoltan
5 February 2015 09:34
#2
sorry for posting, now it seems to work (in theory)
after work when i get back home, i will check on the leds.
osmc@osmc:~$ hyperion-remote --priority 50 --color red --duration 5000
Connected to localhost:19444
Set color to 255 0 0
it dont give errors, i guess then its ok now.
Hi Zoltan,
What type of LEDs are you using?
Zappa
Zoltan
5 February 2015 11:12
#4
WS2801
but right now im not sure that hyperion is working coz i cant see my leds,
i will get back to it after work.
Since i haven’t had an official reply yet: Is there a hyperion app? - #4 by Theetjuh
I’ll do my best to do an install tonight … I’ve had it working on all test and alpha builds.
I can make some test too is you need.
Zoltan
5 February 2015 14:30
#7
Sorry guys but
IT WORKS
i just got home, and the leds are working with rpi2 + osmc + hyperion just like before with rpi + raspbmc + hyperion.
happy
What did you do for that ?
Nothing ?
Zoltan
5 February 2015 14:37
#9
nothing
sudo apt-get update
sudo apt-get install libqtcore4 libqtgui4 libqt4-network libusb-1.0-0 libprotobuf9 ca-certificates
wget -N https://raw.github.com/tvdzwan/hyperion/master/bin/install_hyperion.sh
Zoltan
5 February 2015 14:42
#10
down side is, if the leds are connected to the rpi2 while the ds18b20 therm sensors,
the sensors wont work anymore (needs reboot and leds to be disconnected
It’s good to know that Hyperion is working as expected on Alpha 4 with WS2801s.
Now I just need to figure out why WS2812s using GPIO18 don’t!
nice to hear Hyperion is working. Can you please give a quick start guide? I connected the LED on GPIO 10 MOSI and GPIO 11 SCLK exactly like RPi 1 and istalled Hypeiron like the guide at the Hyperion Wiki but cant geht them work
Anything im doing wrong? I have the RPi2 too.
Hello
Same issues … my hyperion works fine on my RPi B and B+ but impossible to works in Rpi 2 B.
PS : Multiple OS tested for that on Raspberry 2 … No one works yet
@cybertronic
Kill hyperiond
sudo service hyperion stop
Then run it on the console and see if you get any errors
sudo /usr/bin/hyperiond /etc/hyperion.config.json
I tested it last night … just like Zoltan posted … works perfectly.
[quote=“Zoltan, post:9, topic:449”]sudo apt-get updatesudo apt-get install libqtcore4 libqtgui4 libqt4-network libusb-1.0-0 libprotobuf9 ca-certificates
wget -N https://raw.github.com/tvdzwan/hyperion/master/bin/install_hyperion.shsudo sh ./install_hyperion.sh[/quote]
But just like I posted here Is there a hyperion app? it keeps installing x11-common and all the rest of the stuff we don’t need, but is an dependency
Yes but still works after reboot ?
Yup works just normal after every reboot
I can build and ship a version of Hyperion in our applications store which does not dependent on x11-common if it is not a necessary dependency. I’ll email the Hyperion guys tonight.
S
