Just updated and I am facing the “Sadface” right after the boot of my RPI 3. Everything was working fine before that. I can’t enable Debugging or Upload logs because I can’t access the My OSMC interface. But I still can login via ssh.
I’d advise you start fresh. To make it clearer, you have a repository which carries pirate add-ons. We can’t provide support for that. Further, the repository is so large it can reduce system performance
I just reconfigured everything. All went well. I configured Emby and the Theme “The Arctic Zephyr: From Ashes”. After doing a reboot I am back to the “sad face” loop.
I have installed rbp2-mediacenter-osmc (16.0.0-13) via apt-get upgrade now and nothing changed. Still “sad face” loop.
It looks like the theme is to blame here. If I remove it from the guisettings.xml it will boot without a problem. I can than activate the theme via settings->appearance and the theme is working. But as soon as I reboot I will be in the “sad face” loop.
I’m also having troubles with after the latest update and the Arctic Zephyr skin. Sad face…
Is there any way to get the skin working? Or do we have to ask te maker?
I just updated on my rpi 2, sad face too, and can’t ssh as it restarts by itself 5 sec after showing the face… I don’t use many addons, but I had emby, and the theme 1080X (I think it was this one).
My bad, it was not restarting, just the TV… Anyway, after moving .kodi to kodi.bak it actually worked. As I didn’t have much addons it will be easy to find which one is problematic.
Please report back, while one other user said it was actually something from guisettings.xml and he was just able to move the whole kodi folder back excluding the guisettings.xml
mm, no guisetting.xml in my folder, but funny thing, after my changes, I decided to put back my old kodi.bak to .kodi, it actually worked, and then, when I decided to put my skin back (Xperience1080), it crashed. So it seems it was the skin.
