Sad Face after October Update
Evening all,
Thanks for the latest update. The installation appeared to go well, but I’m now getting a sad face/black screen loop after the update (from My OSMC app).
Here’s the logs: http://paste.osmc.tv/ogawemevom
I’ve done some troubleshooting after looking through the logs (though to be honest, I don’t really know what I’m looking for). I’ve so far tried:
*Removing redundant fstab commands from advancedsettings.xml
*Removing redundant fstab and an NFS share reference from Sources.xml
*Connecting the Vero4K+ directly to soundbar (bypassing HDMI switch, which seemed to be reporting incorrect/missing EDID details in the initial logs I pulled)
*Renaming guisettings.xml and rebooting to allow a new file to be created
And the following reinstalls from SSH
sudo rm -r /var/lib/apt/lists/*
sudo apt-get update
sudo apt-get dist-upgrade
reboot
sudo apt-get update
sudo apt-get install --reinstall vero3-mediacenter-osmc
sudo apt-get clean
And renaming .kodi folder, restarting mediacenter with default settings.
But none of the above made any difference, same sad face/black screen loop.
I’m not really sure what I’m looking at but this error reoccurs through the logs. Is it causing the sad face issue?
Oct 19 22:38:59 Vero4 mediacenter[653]: /usr/bin/mediacenter: line 212: 782 Segmentation fault sudo -u osmc MALLOC_MMAP_THRESHOLD_=8192 LIRC_SOCKET_PATH=/var/run/lirc/lircd $KODI --standalone -fs
Oct 19 22:38:59 Vero4 mediacenter[653]: Kodi exited with return code 139 after 0 hours, 0 minutes and 3 seconds
Thanks in advance!
Brian
Did you stop Kodi (mediacenter) before renaming the .kodi directory? Your log was not from a vanilla .kodi.
Also, in the advancedsettings.xml in the provided logs appears to have syntax errors. (It may be a problem with displaying it via the logs. But where you tried commenting out the cache settings is wrong.
Thanks for your reply.
Yes, I stopped Kodi first before renaming the folder. It made no difference and so I reverted that change and didn’t pull logs from the vanilla reboot. I can do that and share both sets of logs if that would be helpful.
Understood on the syntax issue, but I believe I closed the active settings (/advancedsettings) before my ill-attempt at commenting out. The xml has been like that for months and months with many reboots and I believe the June update applied too, so I would’nt have thought that this could be the culprit?
Logs with a fresh .kodi directory would be the best thing for now.
As to the advancedsettings, closing </advancedsettings> in the middle of the file is not good. I can’t tell if it’s causing a problem or not, but it’s surely not what you wanted.
Running into the same issue. I’ve disabled all additional services I am running AFAIK: hyperion and RetroPie app-switcher but no luck. Do you have any additional stuff installed?
clean setup (move .kodi auto of the way).
https://paste.osmc.tv/ogisofowek
This is from a crashlog generated when I ran kodi --standalone -fs
That’s not a full debug log. Please give us full logs.
Had to dig in the advancedsettings.xml (been a while :slight_smile: )
https://paste.osmc.tv/epoyazatos
That is still not a full debug log!
Yes, was just running the grab-logs -A. Haven’t had an issue with OSMC in over 1,5 years so bear with me. It’s all coming back :smiley:
https://paste.osmc.tv/ehuqetejoq
Since Kodi won’t startup I had to dig into the CLI…
So did Kodi start OK with the fresh .kodi? It looks like it did (at least I don’t see the segfault now)
No. It crashes all the time with a segmentation fault.
Could this be the cause:
# apt full-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
  libboost-dev libsdl2-2.0-0 libsdl2-dev
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
Removed the packages and ran an autoclean. Suspect they are some leftover from RetroPie. Still segmentation faults… grrrrr
Opps, I missed that.
Did you update via command line, or MyOSMC?
You shouldn’t be using full-upgrade from the command line. You should use dist-upgrade.
I’m an old-school Unix guy (30 years under the hood) so CLI.
I ran full-upgrade from the CLI like I’ve always done.
# apt dist-upgrade
same as running full-upgrade
From what I understood apt-get dist-upgrade is the equivalent of (the newer) apt full-upgrade.
You’re right. I was thinking just apt upgrade.
Indeed. Upgrade I haven’t used in over 2 years I think. You get an error when you try AFAIK.
I noticed someone has audio issues since the update; his debug logs also contains ActiveAE errors. From what I understand in the kernel messages I get ActiveAE is tainted and causes the segmentation fault.
