Edit (before reading further on – deleting my ~/.kodi/userdata/guisettings.xml file appears to have resolved the issue… I’ll monitor.
Edit 2 Deleting my guisettings.xml file looked like it had resolved the issue, but it hasn’t – 15 minutes later and the sad face loop has returned.
Original post:
Here are my full logs:
http://paste.osmc.io/garizarira
Background: I hadn’t updated OSMC since around January, because although I was notified of an available update, when running it through Kodi I would get stuck on a screen warning that I had modified my smb.conf, so I might need to reconfigure it after the update. This screen required a Yes/No response and as my RPi 2 is behind my TV I’ve been putting it off.
Today I decided to update, so I SSH in and run sudo apt-get update then sudo apt-get dist-upgrade. All appeared to go smoothly and I was able to get past the smb.conf notice.
On reboot, Kodi goes into a ‘sad face’ loop, showing the home screen for a couple of seconds, then the sad face, back to the home screen and so on, around 10 times (for 30 seconds or so).
After that, it’ll stay on the home screen, thumbnails for my recents will appear, and all seems fine, for around 10 minutes or so, when it’ll jump out of whatever I’m doing or watching, back to the sad face loop.
My speculation:
At the end of the system journal log, I see a lot of this, where the timestamps match what I see happening:
Mar 05 16:31:39 osmc mediacenter[293]: terminate called after throwing an instance of ‘std::bad_alloc’
Mar 05 16:31:39 osmc mediacenter[293]: what(): std::bad_alloc
Mar 05 16:31:40 osmc sudo[1407]: pam_unix(sudo:session): session closed for user osmc
Mar 05 16:31:40 osmc mediacenter[293]: Kodi exited with return code 134 after 0 hours, 14 minutes and 55 seconds
Mar 05 16:31:40 osmc kernel: Console: switching to colour frame buffer device 240x67
Mar 05 16:31:51 osmc mediacenter[293]: Starting Kodi…
Mar 05 16:31:51 osmc sudo[1733]: root : TTY=unknown ; PWD=/ ; USER=osmc ; COMMAND=/usr/lib/kodi/kodi.bin --standalone -fs --lircdev /var/run/lirc/lircd
Mar 05 16:31:51 osmc sudo[1733]: pam_unix(sudo:session): session opened for user osmc by (uid=0)
Mar 05 16:31:51 osmc mediacenter[293]: unknown
Mar 05 16:31:51 osmc sudo[1741]: osmc : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/mv /tmp/timezone /etc/timezone
Mar 05 16:31:51 osmc sudo[1741]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 05 16:31:51 osmc sudo[1741]: pam_unix(sudo:session): session closed for user root
Mar 05 16:31:51 osmc sudo[1744]: osmc : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/cp /usr/share/zoneinfo/Europe/London /etc/localtime.dpkg-new
Mar 05 16:31:51 osmc sudo[1744]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 05 16:31:52 osmc sudo[1744]: pam_unix(sudo:session): session closed for user root
Mar 05 16:31:52 osmc sudo[1747]: osmc : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/mv /etc/localtime.dpkg-new /etc/localtime
Mar 05 16:31:52 osmc sudo[1747]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 05 16:31:52 osmc sudo[1747]: pam_unix(sudo:session): session closed for user root
Mar 05 16:31:52 osmc kernel: Console: switching to colour dummy device 80x30
This looks similar to this topic: Kodi 16 keeps on crashing (sad face) every 14-15minutes
However I also found this one: Sad face after update - #22 by Dilligaf
And in my case, if I go into Settings > Services and toggle UPNP, it’ll force a sad face loop.
I’m open to ideas!
