I have used FilmOn for a long time on OSMC_TGT_rbp2_20200402.img and previous versions without problems, while a clean install of later versions gives a ‘sad-face-loop’.
The log is made on a clean install of OSMC_TGT_rbp2_20201227.img, (incl. sudo apt-get clean, sudo apt-get update, sudo apt-get dist-upgrade) on a RasPi 3B.
The problem can easily be reproduced.
Installation of the FilmOn add-on , starts the loop when enabling the add-on.
In order to stop the loop and use ‘grab-logs -A’, I found no other way than to just take out the network cable.
Link to the log (hope it’s OK): https://paste.osmc.tv/rudijixefe
I have tried to google the problem, without success and sincerely hope someone can help me.
