Sad face on RPi after April update
Hello,
My Raspberry Pi doesn’t boot after April update. I am stuck in a “sad face” loop but I am still able to connect with SSH.
Here are the logs : http://paste.osmc.io/fayijujane
Thanks for your help, you’re doing a fabulous job on OSMC.
floyd
Please the free and easy to use search function.
Your log file shows heavy filesystem corruption.
Either your SD card is dying or you have a problem with your power supply.
Do you have another SD card to test?
Thanks fzinken for your feedback. Yes, I have another SD card. Is there any way I can backup my Kodi settings ?
floyd
MyOSMC backup
