I have soudently a problem with scraping with my VERO 4K.
I only add a new HD. So I decided to delete all my Kody library to re start with new informations for movies.
At the begignig all is right. I just had to forced some information about tv show.
I re-started and from this time system clean my library and don’t find information for a lot of movies (now sytstem recognised around 200 movies on around 400 movies in ext.HDs)
And not special movies, a lot of recents movies or block buster. For example it don’t recognise Star Wars or Harry potter, or Antmen…
I already tried to change the scraper (TMDB, TMDB python, Universal TMDB, etc.) a lot of times : but it don’t works.
And I precise that I don’t have change anything with my organisation (file / folder), and more than half of ignored movies are at the same place as before (when they was recognised).
If you have some idee about that I will be happy to ear your reflexions… And perhaps your solutions
Are you’re hdds self-powered connected by an USB hub?
reproduce the issue
If outputting audio in PCM (ie not passthrough AC3/DTS) That is the number of channels that will be output/down-sampled to from sources with more audio channels. Setting it to anything other than 2.0, 5.1, or 7.1 is normally the wrong choice.
You can find information about most settings in Kodi’s wiki such as the one in question being here…
Yes. Since that option is quite broken we have since set the setting to off in the system level advancedsettings.xml which both forces the setting and hides it from the UI. People would enable it without a full understanding of the consequences and would struggle to understand why there were having issues.
