Can you join me here? Kiwi IRC
Correct. I just added another movie, did an update library and got a “double scrape.” When I look at the paths for the two files, one starts with SMB://…, and the other with NFS://…
I can not join the chat. I get the following error:
403 Forbidden
Request forbidden by administrative rules.
I can no longer post replies. It seems I have reached my daily limit. I can only edit this post continuously.
I have rebooted. Several times actually.
Have you rebooted since removing the smb sources?
You should be able to popst again now
List ALL files that you see in /userdata
try now, should be allowed to post
Database
advancedsettings.xml
library
playlists
RssFeeds.xml
favourites.xml
mediasources.xml
profiles.xml
Thumbnails
guisettings.xml
passwords.xml
sources.xml
addon_data
keymaps
peripheral_data
wakeonlan.xml
paste-log mediasources.xml
please
have you rebooted the device throughout all this at all?
I have rebooted twice since starting this thread.
I don’t see any reason for why this should persist. Are you using MySQL or just the default db? My next suggestion is going to be to just wipe the db and start over
How big is your library?? The easy fix is to delete/rename the .kodi folder and start fresh. This will reset everything including librarys.
I’m starting to think there is a bug in the RC.
If it was a bug then you wouldn’t be the only one we’ve seen report it.
Huge. Absolutely grossly massive. My library takes 3 days to scrape for movies alone.
Can your NAS run MySQL? This is a much better solution with such a large lib.
I have never thought about that. I do have two XBMC machines, so the syncing of info would be better between tv. I am running NAS4Free.
Are the other machines more powerful? I’d never let the pi/vero do the scraping to MySQL with such a large lib.
This may be useful -
The other is a Ubuntu install XBMC 12.2. Runs flawlessly! Absolutely love it!
