Script
Hi There is there a script that i can run within OSMC that will do the followning
Every month run sudo apt-get dist-upgrade. instead of me having to manualy type this in everytime.
You can search for how to do unattended upgrades, but we don’t recommend this and it’s not something we support officially.
It’s likely you’ll wake up and say your device doesn’t work as expected or there is a new bug and not realise that such an issue was introduced by a particular update.
Updates are hopefully not frequent enough to disturb you that they can’t just be installed when prompted. The average update takes less than five minutes to install
how do i uninstall a service that i do not want IE Samba or Tranmission
Same way as it has been installed - through MyOSMC App Store.
got mine running on unattended
