Since accepting the 18.4 update I’ve been stuck in a sad face loop. The first things I tried was relocating userdate and .kodi but now I don’t think kodi ever made it that far into launching.
In journalctl I can see only almost instant segfaults but I don’t think any other log files have a chance to be created although I’ll provide anything requested which exists.
Oct 31 22:39:43 osmc mediacenter[325]: Starting Kodi...
Oct 31 22:39:43 osmc sudo[2296]: root : TTY=unknown ; PWD=/ ; USER=osmc ; ENV=LIRC_SOCKET_PATH=/var/run/lirc/lircd ; COMMAND=/usr/lib/kodi/kodi.bin --standalone -fs
Oct 31 22:39:43 osmc sudo[2296]: pam_unix(sudo:session): session opened for user osmc by (uid=0)
Oct 31 22:39:43 osmc sudo[2296]: pam_unix(sudo:session): session closed for user osmc
Oct 31 22:39:43 osmc mediacenter[325]: /usr/bin/mediacenter: line 142: 2296 Segmentation fault sudo -u osmc LIRC_SOCKET_PATH=/var/run/lirc/lircd $KODI --standalone -fs
Oct 31 22:39:43 osmc mediacenter[325]: Kodi exited with return code 139 after 0 hours, 0 minutes and 0 seconds
Oct 31 22:39:54 osmc mediacenter[325]: Starting Kodi...
Oct 31 22:39:54 osmc sudo[2318]: root : TTY=unknown ; PWD=/ ; USER=osmc ; ENV=LIRC_SOCKET_PATH=/var/run/lirc/lircd ; COMMAND=/usr/lib/kodi/kodi.bin --standalone -fs
Oct 31 22:39:54 osmc sudo[2318]: pam_unix(sudo:session): session opened for user osmc by (uid=0)
Oct 31 22:39:55 osmc sudo[2318]: pam_unix(sudo:session): session closed for user osmc
Oct 31 22:39:55 osmc mediacenter[325]: /usr/bin/mediacenter: line 142: 2318 Segmentation fault sudo -u osmc LIRC_SOCKET_PATH=/var/run/lirc/lircd $KODI --standalone -fs
Oct 31 22:39:55 osmc mediacenter[325]: Kodi exited with return code 139 after 0 hours, 0 minutes and 1 seconds
[UPDATE] Fixed in latest version 18.4.0-6 installed with
sudo apt-get update
sudo apt-get dist-upgrade
Thanks for the rapid response last night. Shortly after posting my issue a storm came through and knocked out power until after I left for work this morning. In 5+ years of using OSMC I don’t think I’ve ever even needed to use your wiki or support pages before. Timing my only ever issue to coincide with power and internet outage is convenient and having it all fixed so quickly is outstanding. Many, many thanks
Getting the same issue here, sad face boot loop, I just updated through the OSMC interface (an hour ago), on rpi3.
Luckily it seems indeed to only be OSMC as I can still SSH into the pi.
Same problem for me , after update : Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Nov 1 15:03:22 2019 from 192.168.1.10
osmc@osmc:~$ sudo apt-get update
Get:1 http://security.debian.org stretch/updates InRelease [94.3 kB]
Ign:2 Index of /debian stretch InRelease
Hit:4 Index of /debian stretch-updates InRelease
Hit:5 Index of /debian stretch Release
Hit:3 Index of /osmc/osmc/apt stretch InRelease
Fetched 94.3 kB in 2s (37.1 kB/s)
Reading package lists… Done
osmc@osmc:~$ sudo reboot
I leave in France, have I to wait for have the good update ?
Building dependency tree
Calculating upgrade… Done
