Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Nov 1 15:55:57 2019 from 192.168.1.10
osmc@osmc:~$ sudo apt-get update
Hit:1 http://security.debian.org stretch/updates InRelease
Ign:2 Index of /debian stretch InRelease
Hit:4 Index of /debian stretch-updates InRelease
Hit:5 Index of /debian stretch Release
Hit:3 Index of /osmc/osmc/apt stretch InRelease
Reading package lists… Done
Building dependency tree
Calculating upgrade… Done
This whole thing is pretty much garbage. Aside from plowing through Help Pages for installing the OSMC Installer (written during the Jurassic Age) for Ubuntu users - the current version the Installer grabs errors-out as well.
So - to recap: Not only did the latest update totally crash my Pi., the latest version of the release is also a failure. Burn a few more hours of my day re-configuring my Pi because somebody published a beta version of goo.
Can you guys at the minimum update your help pages?
At the terminal just type in grab-logs -Aand after a few moments it should come back with a web address of where your logs were uploaded to. We need you to give us that web address so we can try to figure out what went wrong for you.
osmc@osmc:/$ sudo systemctl stop mediacenter
osmc@osmc:/$ sudo apt-get clean
osmc@osmc:/$ sudo apt-get install --reinstall rbp2-mediacenter-osmc
Reinstallation of rbp2-mediacenter-osmc is not possible, it cannot be downloaded.
osmc@osmc:/$ sudo systemctl start mediacenter
Is something blocking its access to the internet? That package is your issue as you have 18.4.0-5 and that was replaced in the repository with 18.4.0-6. I ran those commands before posting that and it worked as it should and it downloaded and installed the correct package.
