Thank you – this really is appreciated.
Hello, my OSMC works after the below commands.
Thank you for your precious aid.
sudo rm -r /var/lib/apt/lists/*
sudo apt-get update
sudo apt-get dist-upgrade
reboot
After having read about the issues, I did not check for the update. Is it safe to install v 18.4 update now or should I wait for the next update to avoid the issue altogether?
The sad face reboot issue was resolved and it only affected people who downloaded the update in the first couple hours after its release.
Thanks for the info. Will give it a go tomorrow.
