I installed https://www.vultr.com/docs/setup-vsftpd-on-debian-ubuntu hoping that FTP would be faster than sFTP. No luck.
Via iperf I get awesome speeds, but only 4-5 MB/s via FTP and sFTP.
Any clues as to why?
Thanks!
Thanks!
Have you installed the FTP Server from My OSMC -> App Store?
Sorry, sam - I just edited my question to qualify it.
Probably best to use the optimised vsftpd in the App Store
Fully purge the current version you have.
Also helps to know where you’re transferring files to?
Thanks Sam, done now - did not make a difference.
I a writing to a USB attached 7200 HDD.
I just tried upping directly to the /movie folder (ie. not to the USB) - same slow speeds.
Are you using a wired LAN connection or a wireless one?
It’s wired through a switch.
How is the disk formatted?
I think it is exfat
Also, I wanted to try via SMB, but I cant see the USB HDDs there.
I connect fine, but can only see the /movies, /music, /pictures & /TV shows. I did try to chown the media folders - no luck.
Can you select / ? Your drives should then be mounted in /media.
exFAT probably goes through FUSE so will slow things down.
Use ext4 if you can
No, I can’t seem to go up to /
OK, I generally go with exFAT to move drives from my Mac to other OS’s.
Ok, don’t let us mix things up. Samba is not the theme of this topic.
Just to be sure we have the same stand of information:
Can you confirm this?
Yes, I can confirm that. I can also confirm that I get the same speeds if I ftp to the /movies dir (ie. not on the USB drive). I also tried both sFTP and regular FTP.
I CAN push it a bit higher if I transfer several files at the same time.
It’s no biggie, I can just set the transfers over night. But it is odd. I can transfer through the public internet faster than this.
Mmhhh , I just formated a USB 3.0 prendrive to exFAT:
I get 8.4 MB/s pushing data and 11.3 MB/s getting stuff from the Vero.
With ext4 filesystem on the stick I get full speed in both directions, as Sam predicted.
Can you SSH into the Vero and
/etc/vsftpd.conf line xferlog_enable=YES
sudo systemctl restart vsftpdsudo paste-log /var/log/vsftpd.log and provide the return URL heresudo findmnt -A|paste-log and provide the URL hereThx
