Sizzle on jack with my Rpi 2
Hi everybody !
after installing OSMC on my rpi2, wanted to watch a movie, BUT i had a big problem !
endeed i have a sizzle in my speaker ( they are plug with jack on Rpi 2 ) so i canhear the movie but with big sizzle :frowning:
do you have a solution ?
Thank you :slight_smile:
And my Pi is inside a plastic box
Sorry for my bad english its not my native language :confused:
Hi Aornn
you know this is not the OpenElec Forum? :blush: If you have problems with OE better ask in there forum.
If you like to try OSMC you are welcome :smile:
To you the audio jack for movies is not a good idea. Why donโ€™t you use HDMI for audio?
Yes my bad ^^ I confused the two distributions ^^
Because on my screen there is no speaker its itโ€™s a computer screen :confused:
Edit: When i use an 3.5 jack with 4 position there is litlle sizzle but its ok so how can i do for have a better audio sound on analog ?
Check this: https://discourse.osmc.tv/t/no-headphone-audio-how-to-configure-in-osmc/3790
http://openelec.tv/forum/124-raspberry-pi/75330-rpi-2-analog-audio-jack-static-noise
http://kodi.wiki/view/Raspberry_Pi_FAQ#Video_and_audio_output_on_the_Raspberry_Pi
Thanks it is all good
When i use an 3.5 jack with 4 position there is sizzle buti think this is the best quality that I can had so how can i do for have a better audio sound with the analog ? I heard talk about DAC
Thatโ€™s why I told you before itโ€™s a bad idea. Audio Quality isnโ€™t really good over the jack.
I donโ€™t know much about DAC. As much I know HiFIBerry is quite common and has OSMC support.
But better you double check before you order anything.
Try this one too: Noise on Analog Audio Line - #11 by DBMandrake
I got much better analog audio through a USB sound card (<$5 on eBay)
i think i will buy dac pcm2704 or hifiberry RCA
