I’ve been experiencing some issues since the April update relating to skip 10s forward/backwards and pausing. If I play a video and later pause it, skip backward doesn’t function. If I try to unpause the video the OSD appears with the elapsed time but the video does not resume. If I skip forward while paused the video sometimes unpauses on its own.
P.S. A very minor detail. I see a mouse pointer appearing in the upper left screen after a reboot. It does disappear on its own so it’s not an issue, however, I don’t believe this happened before the April update.
I’m facing something similar since I updated a couple of days back.
Pressing the right or left button to skip forward/backward “pauses” the video and shows “buffering” but it stays that way. Have to stop and play the video again.
Never experienced this behavior before the update.
Hi all, I registered here to get some help. I see that I am not alone with this skipping forward/backward problem.
I had no problem prior to the latest update. I record TV programmes to a NAS. MediaInfo of a recording:
Interestingly, if I edit out sections of a recording (adverts) using VideoReDo, the saved edited recording plays and skips back and forth perfectly!
I would be very grateful if you could look into this.
Thanks.
General
Complete name : \NSA310\video\TV Recordings\Narrow Escapes__Channel 4 HD__02-05-2024_16-00.mpg
Format : MPEG-TS
File size : 2.00 GiB
Duration : 1 h 9 min
Overall bit rate : 4 098 kb/s
Frame rate : 25.000 FPS
FileExtension_Invalid : ts m2t m2s m4t m4s tmf ts tp trp ty
Video
Menu ID : 17664 (0x4500)
Format : AVC
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : 27
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Active Format Description : Letterbox 16:9 image
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Muxing mode : LATM
Codec ID : 17-2
Bit rate mode : Variable
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Delay relative to video : -730 ms
Language : English
Editorial classification : Main
Mix type : Independent
Text
Format : DVB Subtitle
Codec ID : 6
Delay relative to video : 2 s 680 ms
Language : English
Menu
Format : AAC / AVC / DVB Subtitle
List : 302 (0x12E) (AAC, English) / 301 (0x12D) (AVC) / 305 (0x131) (DVB Subtitle, English)
Language : English / / English
2024-05-02 15:00:00 UTC : en:Narrow Escapes / en: / / / 01:10:00 / Running
reproduce the issue
I had a quick look today. I can reproduce that issue on my 4k+, but on my V it behaves as it should. So it’s something special to the 4k/4k+. In the logs I can see that the video player thread seems to stop working after pressing pause. I have no idea why. That needs to be debugged, but as I’ve mentioned above, it will take some time …
Well thanks for that - I think I’ll wait for the fix, though
I appreciate your effort in posting the walkthrough, and in the future I’ll make backups, but I don’t have time right now to do that.
Hi here,
I have a similar issue on my Vero 4k since the april update.
When I pause a video, then I resume, nothing happens. I have to exit from the video, then run it again. But the time is not remembered, I have to move forward (if I know where I was!).
It seems random though, it didn’t happen every time (I’d say, once in two).
I didn’t have this issue before this update, everything was working before.
I will try to have logs (but I need to know how to do this before).
