Got my Vero 4K today and so far it only has one major issue. It will not boot with my external drive connected.
It is an 8TB powered external drive formatted in NTFS. If it is connected when the Vero tries to boot, all I get is a screen saying ‘Please Stand By’ and an infinite boot loop.
I have tried with a flash drive 64GB in NTFS and that is fine. I still get a flash of the ‘Please Stand By’ screen, but it then goes on to boot up.
I can only imagine what will happen when I get home later and connect it to my USB hub with a further 10TB of storage connected!
Unfortunately I now have a more pressing problem. No digital audio passthrough is working with my amp. Granted the amp is old, but DD 5.1 and DTS worked fine on my Wetek Core.
My amp is connected through optical and I have enabled ‘passthrough’ and ‘AC3 capable reciever’ and ‘DTS capable reciever’ (in fact, I think I have tried every single setting combination at this point), but none of them trigger my amp to go into DD or DTS mode. It just stays in ‘Pro Logic’ mode for everything.
There is one way I can get a digital signal through, and that is by turning on ‘AC3 Transcoding’. This triggers my amp into DD mode as soon as a file (AC3 or DTS) is played, but I don’t want everything transcoded, only the formats my amp cannot process.
I did notice that under ‘Passthrough output device’ it says: AML-M8AUDIO, HDMI but I don’t know if the HDMI is significant.
I also have a choice of ‘Audio output device’ which is: Default (AML-M8AUDIO Analog), PCM or AML-M8AUDIO, HDMI. However I didn’t find either passed through the correct audio.
Maybe I just haven’t hit on the right combination of settings yet.
Yeah, unfortunately that doesn’t work.
That is how I set it at first because that is how I had my Wetek Core set up.
I can’t even force my amp into DD/DTS mode, it isn’t having any of it!
I am fine with removing the drives for a reboot (as it is hardly ever needed), my concern is the rest of the family who will not understand why it doesn’t boot after a crash or something. Hopefully a fix won’t be too difficult or far off. I understand OSMC should not be closely compared with Open/Libre ELEC, but the drive caused no issues with these two OS’s. Maybe that info will help, I don’t know.
I suspect you ran LibreELEC on a different class of hardware however.
The crash occurs before OSMC even starts, because of a bug with Seagate drives that cause issues with our bootloader.
