I unplugged recently my RPI (it was a not intentional…) and since then I have a sad face on the screen…
I saw on this forum that it was related to Kodi crashes.
I executed sudo apt-get update && sudo apt-get dist-upgrade && sudo reboot whitout trouble but I still have the sad face. I also tried to hold ctrl+shift during the boot, and still no change…
I wanted to look at Kodi logs but my ~/.kodi/temp/kodi.log file is empty…
If you can’t even log in it sounds like there are major problems that could be hard to diagnose or repair. Your best bet is probably to do a fresh install.
