So this is where in that log your seeing a freeze?
020-11-06 10:50:50.955 T:3542085856 DEBUG: CDVDClock::ErrorAdjust - CVideoPlayerAudio::OutputPacket - error:20447.604376, adjusted:41708.333333
2020-11-06 10:50:53.705 T:3500392672 DEBUG: CPtsTracker: detected pattern of length 1: 41708.24, frameduration: 41708.333333
and
2020-11-06 10:51:14.951 T:4024430816 DEBUG: ActiveAE::SyncStream - average error of 117.613773, start adjusting
2020-11-06 10:51:15.036 T:4024430816 DEBUG: ActiveAE::SyncStream - average error 21.613773 below threshold of 30.000000
I’m at a loss here as when I play the same file I get the same initial audio syncs but playback with both audio and video is flawless.
My log during playback
2020-11-06 10:55:27.934 T:4071698448 DEBUG: ------ Window Init (VideoFullScreen.xml) ------
2020-11-06 10:55:27.957 T:4071698448 NOTICE: Whitelist search for: width: 1920, height: 1080, fps: 23.976, 3D: false
2020-11-06 10:55:27.957 T:4071698448 DEBUG: Whitelist is empty using default one
2020-11-06 10:55:27.957 T:4071698448 DEBUG: Trying to find exact refresh rate
2020-11-06 10:55:27.958 T:4071698448 DEBUG: Matched exact whitelisted Resolution 1920x1080 @ 23.98 - Full Screen (23)
2020-11-06 10:55:27.958 T:4071698448 NOTICE: Display resolution ADJUST : 1920x1080 @ 23.98 - Full Screen (23) (weight: 0.194)
2020-11-06 10:55:27.961 T:3308396768 DEBUG: OnAVChange: CApplication::OnAVChange
2020-11-06 10:55:27.963 T:4071698448 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
2020-11-06 10:55:28.005 T:4029567200 DEBUG: ActiveAE::SyncStream - average error of -49.717028, start adjusting
2020-11-06 10:55:28.005 T:4029567200 DEBUG: ActiveAE::SyncStream - average error -17.717028 below threshold of 30.000000
2020-11-06 10:55:28.007 T:4062179552 DEBUG: CEGLNativeTypeAmlogic: Detected HDMI switch
2020-11-06 10:55:28.102 T:3870503136 DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnAVChange - data: {"item":{"title":"DuckTales.2017.S03E13.Escape.from.the.ImpossiBin.1080p.AMZN.WEB-DL.DDP2.0.H.264-LAZY.mkv","type":"movie"},"player":{"playerid":1,"speed":1}}
2020-11-06 10:55:28.104 T:3870503136 DEBUG: Previous line repeats 1 times.
2020-11-06 10:55:28.104 T:3870503136 DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnAVStart - data: {"item":{"title":"DuckTales.2017.S03E13.Escape.from.the.ImpossiBin.1080p.AMZN.WEB-DL.DDP2.0.H.264-LAZY.mkv","type":"movie"},"player":{"playerid":1,"speed":1}}
2020-11-06 10:55:28.105 T:3870503136 DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnAVChange - data: {"item":{"title":"DuckTales.2017.S03E13.Escape.from.the.ImpossiBin.1080p.AMZN.WEB-DL.DDP2.0.H.264-LAZY.mkv","type":"movie"},"player":{"playerid":1,"speed":1}}
2020-11-06 10:55:29.072 T:3468681440 DEBUG: CDVDClock::ErrorAdjust - CVideoPlayerAudio::OutputPacket - error:-27544.665404, adjusted:-27544.665404
2020-11-06 10:55:32.834 T:3838013664 DEBUG: CPtsTracker: detected pattern of length 1: 41708.24, frameduration: 41708.333333
2020-11-06 10:55:57.962 T:3543167200 DEBUG: Thread JobWorker 3543167200 terminating (autodelete)
2020-11-06 10:55:57.963 T:3300004064 DEBUG: Thread JobWorker 3300004064 terminating (autodelete)
2020-11-06 10:55:57.963 T:3308396768 DEBUG: Thread JobWorker 3308396768 terminating (autodelete)
2020-11-06 10:59:14.965 T:4043301088 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 50ms
2020-11-06 10:59:14.966 T:3308396768 DEBUG: Thread Timer start, auto delete: false
2020-11-06 10:59:14.972 T:4071698448 DEBUG: Keyboard: scancode: 0x80, sym: 0x0151, unicode: 0x0000, modifier: 0x0
2020-11-06 10:59:14.979 T:3308396768 DEBUG: Thread Timer 3308396768 terminating
2020-11-06 10:59:15.012 T:4071698448 DEBUG: Keyboard: scancode: 0x80, sym: 0x0151, unicode: 0x0000, modifier: 0x0
2020-11-06 10:59:15.013 T:4071698448 DEBUG: HandleKey: stop (0xf0bc) pressed, action is Stop
2020-11-06 10:59:15.013 T:4071698448 NOTICE: CVideoPlayer::CloseFile()
Maybe @grahamh has a clue that I don’t. I’m out of ideas.
You will probably want to turn the HPD lock back off since it didn’t help with your issue.
