Hello!
I had this bug for ages, the remote repeats inputs way too fast.
I’ve been fiddeling with the configuration in /home/osmc/.kodi/userdata/peripheral_data/rpi_2708_1001.xml
<setting id="button_release_delay_ms" value="0" /> (tested values between 0 and 2500)
<setting id="button_repeat_rate_ms" value="500" /> (tested values between 0 and 2500)
<setting id="double_tap_timeout_ms" value="600" /> (tested values between 0 and 2500)
but whatever I set these to it does not seam to change anything.
I’ve also tried advancedsettings.xml
<advancedsettings>
<remoterepeat>800</remoterepeat>
</advancedsettings>
but no fix…
Any ideas out there? Been annoying me for a long while now.
If it makes any difference, its cec over hdmi with a panasonic plasma.
output from the log:
fastest possible click (hard to accomplish):
14:17:12 T:1861219360 DEBUG: PushCecKeypress - received key a8 duration 0
14:17:12 T:1956941824 DEBUG: OnKey: 168 (0xa8) pressed, action is Right
14:17:13 T:1861219360 DEBUG: PushCecKeypress - received key a8 duration 76
normal click (only jumped once):
14:17:11 T:1861219360 DEBUG: PushCecKeypress - received key a8 duration 0
14:17:11 T:1956941824 DEBUG: OnKey: 168 (0xa8) pressed, action is Right
14:17:12 T:1861219360 DEBUG: PushCecKeypress - received key a8 duration 207
just a bit longer, jumps twice… :
14:17:13 T:1861219360 DEBUG: PushCecKeypress - received key a8 duration 0
14:17:13 T:1956941824 DEBUG: OnKey: 168 (0xa8) pressed, action is Right
14:17:14 T:1861219360 DEBUG: PushCecKeypress - received key a8 duration 0
14:17:14 T:1956941824 DEBUG: OnKey: 168 (0xa8) pressed, action is Right
14:17:14 T:1861219360 DEBUG: PushCecKeypress - received key a8 duration 349
