My previous installation of 2017.12-xx started crashing, so I decided to make clear re-install of my RPi2B from scratch.
I used the OSMC_qt_host_installer.exe and I did install 2017.01-1.
I did system update, restart, I dd all the system setup under Master user and scan NAS for movies/series … I took several hours
Then I created profile for “parents” and “kids”… however when I tried to login to any of these profiles … it crashed and I saw blue screen with smile
Any idea? Why 2017.01-1 profiles crash?
Im gonna do install 2016.12-1 now… hopefully profiles will work.
Actually the “crash profile” crash is also in the 2016-12 release of some kind as well
I just did clean install of 2016-12, I can create profiles and login to them, but if I do steps as below the Kodi crash!
clean install + login as Master
create profiles: kids and parents
login as kids and setup profile
logout kids … crash
login as parents + setup profile
logout parents … crash
login as parents … OK
login as kids … crash
login as kids … OK
logout kids … crash
login as kids … OK
logout kids … crash
login as parents … crash
So, every time I login to the same profile as it was logged previously … it is OK and logout is OK too …
But, if I login as different profile as it was logged previously … it crash on login and on logout …
I have the same issue after updating to Krypton as well (but on a pi 3B). Have 2 profiles, neither will log in. Have the error log here, hope it may be of help.
Thanks, that worked!
Changed in my profiles.xml to
useloginscreen=false
autologin=0
Using two profiles with MySQL database setup. Running Pi2. Managed to recreate the issue after reinstall and restore of .xml files(didn’t try without MySQL setup however). Sorry, don’t have log files, as they were overwritten when it worked again.
Add the following line: deb http://apt.osmc.tv jessie-devel main
Awesome. I was just updating and wondered why I don’t get my profiles to work. Taking a look at the forums and there you go, magic Sam has already fixed it a couple of minutes ago. Thanks a lot!! <3
After update received via modification of /etc/apt/sources.list file problem still appears. I have two profiles and during logging to anyone I can still see only sad face. I have raspberry 1.
Any idea what I should do?
Szymon
I applied the update but both profiles are sad face. How do I re-install the Krypton Update and start over again with a single profile and default skin?
I may have spoken too soon. It does now allow me to log in to my other profiles, but I am seeing all kinds of PVR add-on errors that did not exist before. Not sure how to get rid of this, I don’t have any PVR hardware, and I don’t want to use any of the Live TV/PVR functionality. How can I get rid of this?
