Squeeze center (LMS) on OSMC
Hi guys
Wondering if this is possible? Lots of discussion on debian install which seems quite convoluted here: http://forums.slimdevices.com/showthread.php?91014-Ubuntu-11-10-Install-error&highlight=mythtv
Tried following this http://www.havetheknowhow.com/Install-the-software/Install-Squeezebox-server.html, but the repo seems to be broken “unable to locate package” and dependency errors.
Tried downloading the .deb Some Software Beta Downloads - Version 7.7 and moving the package to /var/cache/apt/archives/ before installing, but no bananas! I get logitechmediaserver depends on perl (>= 5.8.8); however: Package perl is not installed. Should I be installing Perl?
Should I give up? :smile:
yes you should install Perl since LMS is built on Perl :smile: and then dpkg -i (name of lmspackage).deb to install lms
if you cant figure out how to i can make a a tutorial this weekend
Ok Thanks Toast! Just trying to figure out how and it doesnt seem easy. Reading that Perl should be installed by default but guessing it may have been stripped out to make OSMC perform better. Do you think installing this on my Pi2 would kill it performance wise?
Appreciate a guide thanks if you think its worth doing…
It wont slow down performance and yes perl is installed per default
so just dpkg -i (name of the package)
and then set it up
Hi. I am also struggling with this. Not sure how to install perl (or if I even need to?). Any help would be greatly appreciated.
Thanks.
sudo apt-get install perl
wget http://downloads.slimdevices.com/nightly/7.9/sc/a7665ca/logitechmediaserver_7.9.0~1440333638_all.deb
sudo dpkg -i logitechmediaserver_7.9.0~1440333638_all.deb
then wait
Selecting previously unselected package logitechmediaserver.
(Reading database ... 60240 files and directories currently installed.)
Preparing to unpack logitechmediaserver_7.9.0~1440333638_all.deb ...
Unpacking logitechmediaserver (7.9.0~1440333638) ...
Setting up logitechmediaserver (7.9.0~1440333638) ...
Adding system user `squeezeboxserver' (UID 109) ...
Adding new user `squeezeboxserver' (UID 109) with group `nogroup' ...
Not creating home directory `/usr/share/squeezeboxserver'.
Processing triggers for systemd (215-17+deb8u1) ...
then
http://(yourosmcip):9000/settings/server/wizard.html
or you could go with subsonic
wget wget http://downloads.sourceforge.net/project/subsonic/subsonic/5.2.1/subsonic-5.2.1.deb
sudo apt-get install openjdk-7-jre-headless
sudo nano /etc/default/subsonic
change this line
SUBSONIC_USER=root
to
SUBSONIC_USER=osmc
then
sudo service subsonic restart
access subsonic
http://(yourosmcip):4040/
then setup remote access
http://www.subsonic.org/pages/getting-started.jsp#2
good luck have fun :smile:
Thanks for the quick reply!
I tried what you suggested but I’m getting this back…
dpkg: dependency problems prevent configuration of logitechmediaserver:
dpkg: error processing package logitechmediaserver (–install):
dependency problems - leaving unconfigured
Processing triggers for systemd (215-17+deb8u1) …
logitechmediaserver
What am I missing? Thanks again
After trying to install perl I got this…
osmc@osmc:~$ sudo apt-get install perl
Reading package lists… Done
Building dependency tree
You might want to run ‘apt-get -f install’ to correct these:
perl : Depends: perl-modules (>= 5.20.2-3+deb8u1) but it is not going to be installed
Depends: libgdbm3 (>= 1.8.3) but it is not going to be installed
E: Unmet dependencies. Try ‘apt-get -f install’ with no packages (or specify a solution).
Tried running sudo dpkg -i logitechmediaserver_7.9.0~1440333638_all.deb again but still not recognising perl?
try aptitude install perl then might give a solution too your problem
Thanks a lot for your help, can probably tell I’m new to this haha!
Might have a look at what subsonic is like at some point.
Thanks again.
yo - this dude seems to be on the money… http://forums.slimdevices.com/showthread.php?41188-How-to-Install-Perl-5-8-8-on-Clarke-Connect
or
sudo apt-get install aptitude
sudo aptitude install perl
woohooo - think it just worked for me!
getting required perl 5.8.8 from here- wget http://cpan.org/src/perl-5.8.8.tar.gz
then just running:as per toasts earlier post…
now I can logon to LMS via web browser to my Pi’s IP port :9000
hello- just a quick update on this…
seems Ive made my system fairly unstable messing about with this! maybe too much trial and error I may have to do a rebuild :frowning:
pulsar addon doesnt work anymore since the last OSMC update too, not sure if related to what Ive butchered here!
Installed google play plugin too which may have made things worse…LOL LMS seems to crash regular. went to bed last night switching TV & AMP off, …4:30am I think the Pi crashed, rebooted & auto started my music playlist turned tv & amp on nice n loud! haha missus wasnt happy!
congrats dunno how you managed to do that mine is running stable over 100 days of uptime
try removing and purging packages and redo the installation
