hello everybody. i have an ssd drive and doesn’t work. so i bought the powered USB hub from OSMC but still it doesn’t work. what am i doing wrong?
Suggest to open a new thread and attached the URL for the logs you can upload via MyOSMC → Log Uploader.
Although I agree with fzinken’s post above, since it is somewhat related to the OP you should be aware that not all USB hard drive adapters are natively supported by Linux. It might be prudent to search the innerwebs for whichever drive/adapter your using as it pertains to Linux support just to make sure that it would be expected to work in the first place.
ok . how do i make al log and post it here
so vero 4k+ runs on Linux
Yes, OSMC is based on Debian.
Go to MyOSMC -> Log Uploader upload the full log and share the URL here
sorry i dont understand this
reproduce the issue
upload the log set (all configs and logs!) either using the
