i own 2 Vero 4K, sometimes when they crash, i just use SimplePi or Command Pi from my iPhone to restart the devices.
i was able to do this, with both my 4K’s but lately, only one of them will connect.
they are both connected to the same network, today i tried with a fresh build, the problem is the same.
it’s probably network related, just wanted to hear if someone else have any troubleshooting ideas - ssh from putty works fine.
yeah well sometimes they freeze up, and i have to unplug the device, that do not happen so often, so that’s okay.
but when they do, i would like to reboot them remotely…
i tried changing the IP, also tried connecting when the device is functional, it’s really strange that the other device is working perfectly…
Well you write Putty is working. So I doubt it is a IP Adress problem. Suggest next time to login into with Putty and then try simplepi and after simplepi not working check sudo journalctl -f
Oct 19 15:25:44 osmc sshd[1306]: Accepted password for osmc from 192.168.1.117 port 55662 ssh2
Oct 19 15:25:44 osmc sshd[1306]: pam_unix(sshd:session): session opened for user osmc by (uid=0)
Oct 19 15:25:44 osmc systemd[1]: Starting Session c5 of user osmc.
Oct 19 15:25:44 osmc systemd[1]: Started Session c5 of user osmc.
Oct 19 15:25:44 osmc systemd-logind[297]: New session c5 of user osmc.
Ok so actually the two Vero’s have been updated slightly differently with one of them not have applied the security update.
From the non-working one can you post ls -lah /etc/ssh/ | paste-log
Ok, to be honest the “not working” Vero is actually the one that has the security patch correctly installed. And it is not that easy to refered that. Also as that would make it more insecure I would not recommend it and would suggest to check if there is an updated version of simplepi that support the newer keys.
[quote=“Ben1984, post:19, topic:39352”]
don’t think it can solve my issue, as the one with the fresh build is not working just want to rule that out
[/quote}
Ok, but then you have two not working ones and can then try to find a new simplepi version
If there is no newer simplepi version we can discuss other solutions
