Had my 4k for maybe 2 weeks so far. I’ve used it maybe twice since setting it up (amp is in the shop, so waiting for that to come back) Came home tonight to find it in the
Blue light “Please stand-by” - red light - blue light “Please stand-by” loop
Had a search around, nothing obvious.
tried leaving power off
No external devices plugged in
tried a reinstall with 2 usb sticks
tried a recovery with same 2 usb sticks
All result in the same… 2-3 minutes to get to blue light after power is restored, then boot loop resumes.
Not sure I can get logs as it doesn’t boot far enough to do anything. Even if I did manage to get ssh access it would reboot before I even had chance to login I reckon.
Ok so . . . Update. I’ve installed the latest version came back up, great. Sorted out all my settings again . . . No less than 12 hours later and it’s doing it again.
Please standby , reboot, please standby, reboot. I think it may be faulty.
Hi Sam, ok. to be sure this morning I restored from scratch , set the language and did nothing else. I left it for a few hours and now the same thing again. Seems more sporadic now of anything. Every 5 seconds or so. Can do a video if it’ll help.
After receiving the return, I couldn’t reproduce the problem with the device. We have swapped over the power supply for good measure. That should do the trick.
Hi. I see this is an old thread but I am now having the same issue described here. Red and blue flashing light, stuck in the ‘please stand by’ logo. Haven’t changed anything and was working fine 3 days ago, albeit I do have auto-updates on. Connections are Bluetooth, hdmi, and network.
Installed the software on a MicroSd card, followed the instructions, no good
Tried above on a usb, same
Tried both USB and SD card while pressing the button inside the round port for 30 seconds or more, no action
The unit now sits with a red light for about 20 seconds, flashes once, steady for a few more, then flashes three times. Sometimes I just get a random combo of flashes (1, 23, or 4) at random time intervals
Any thoughts?
EDIT: I also changed the file name from kernel to recovery as suggested
